  • PMLT-TL05 1-1/2" Speaker Pole Mount Top Hat
CLEARANCE PMLT-TL05 1-1/2" Speaker Pole Mount Top Hat
Factory Buyouts
Part #299-2355
Factory Buyouts
Part #299-2355
Model: PMLT-TL05
Quickly and easily transform any speaker design into a pole mount speaker with this steel 1-1/2" top hat from B-52. Just drill a 1-3/4" hole in the bottom of your enclosure and install.
  • Solid steel construction to withstand some abuse
  • Allows any speaker to mount on a 1-1/2" diameter pipe
  • 4" deep socket provides a stable mount
  • Airtight construction keeps enclosures sealed
Quickly and easily transform any speaker design into a pole mount or tripod mount speaker with this steel 1-1/2" top hat from B-52. Just drill a 1-3/4" hole in the bottom of your enclosure and install.
Specifications: • Socket diameter: 1-1/2" (38 mm) • Depth: 4-1/8" • Cutout: 1-3/4" • Screw hole spacing: 3" center-to-center across • Overall diameter: 4-3/8".
For over 30 years, B-52 has manufactured Pro Audio gear in California using only high quality components. We recently acquired tons of product from them so they could free up space in their warehouse. This huge buyout of woofers, compression drivers, horns, crossover components, and cabinet hardware is listed here for a fraction of what you would normally pay. Many drivers in this factory buyout are New Old Stock (NOS) from famous brands and would be considered vintage. Like the B-52 bomber, this factory buyout travels the globe and includes drivers manufactured by famous brands around the world in places like the UK, USA, Denmark, and Brazil. This is a one-time buyout opportunity so quantities are limited.
BrandFactory Buyouts
ModelPMLT-TL05
Part Number299-2355
UPC848864052953
Weight0.95
