  • PKCELL Flat Top 26650 3.7V 5000mAh Rechargeable Li-Ion Battery
PKCELL
Part #142-207
PKCELL
Part #142-207
Start a new portable audio or LED light project with this long lasting 26650 5000mAh Li-ion battery by PKCELL.
  • 5000 mAh for current hungry devices
  • Long lasting standby charge
  • Standard size 26650 Li-Ion battery
  • CE certified for safety
Your Price: $9.98
MSRP: $15.99
Save $6.01 (38%)
Quantity:Qty: 1-3 $9.98/ea
Quantity:Qty: 4+$8.49/ea
Order in the next 0 hr 54 min to ship today. Details
51In Stock
A growing number of electronic devices use 26650 Li-Ion batteries. Larger flashlights are using the 26650 battery to power current hungry LED bulbs, and to provide longer standby time when not in use. Previous rechargeable battery flashlights had to be left on the charger almost all the time so that it would be ready to use in a moment's notice. This PKCELL 26650 5000 mAh Li-Ion battery can be left off the charger for months and still have over 90% of its charge. This enables you to charge an extra battery and have it ready to use in your flashlight in case you are going to be away from electricity for a long period of time or you forget to charge your original battery.
Note: Do not throw the battery into the fire. Do not solder directly to the battery. Do not store the battery in heavy static electricity areas. Do not mix the battery with different brands, chemicals, or amperage ratings. Wash your skin or clothing immediately if the battery leaks onto them. If any chemicals get into your eyes do not rub them, but wash your eyes with clean water and call a doctor. Keep out of reach of young children to avoid swallowing.
Specifications: • Voltage: 3.7 VDC • Current rating: 5000 mAh • Charging environment temperature range: 32° to 113° F • In use temperature range: -4° to 140° F • Size: 1.05" Dia. x 2.56" L (36.8 x 65 mm).
BrandPKCELL
Part Number142-207
UPC848864056906
Weight0.24
Size26650
TechnologyLi-Ion
Voltage3.7V
