  • PC Board M3 Standoff Kit with 8 pcs 16mm and 8 pcs 10mm Stud / 4 pcs 10mm / 8 pcs Phillips Screws
Part #320-3290
Part #320-3290
This standoff kit is perfect for stacking multiple PC boards that are the same size, like the KAB-250 amp board on top of the KAB-BE battery board. They also help secure PC boards inside project boxes.
  • Saves space by stacking same size PC boards
  • Supports PC boards inside metal or plastic enclosures
  • Standoffs have the same M3 thread as the KAB-AB mounting bracket for quick installation
Your Price: $5.98
MSRP: $6.99
Save $1.01 (14%)
Order in the next 2 hr 40 min to ship today. Details
Stack multiple PC boards together or secure a single one with this 20 piece PC board standoff kit. Stacking PC boards enables you to use a smaller project box to install your project in. These standoffs will secure a single PC board, or a stack, if you use it with KAB-AB mounting bracket. They both use the same M3 thread.
Specifications: • Stud total dimensions with thread: Eight 16.25 mm L x 4.6 mm Dia., eight 22 mm L x 4.6 mm Dia. • Standoff dimensions: Four 10 mm L x 4.6 mm • Screw length: Eight 6.8 mm • Thread size on studs and screws: M3 • Thread length on standoffs: 5 mm.
Part Number320-3290
UPC848864049779
Unit of MeasurePackages
