  • Dayton Audio KAB-AB L-type Aluminum Bracket for Bluetooth Amplifier Boards
Dayton Audio
Part #325-114
Dayton Audio
Part #325-114
Model: KAB-AB
The KAB-AB L-type aluminum bracket is ready to protect and mount most Dayton Audio KAB Bluetooth amp boards. Check the dimensions of the board to verify.
  • Heavy duty aluminum bracket will not crack or bend
  • Four permanently mounted standoffs ready for quick installation
  • Four included security screws mount the board to the bracket
  • Seven precut slots in the aluminum for horizontal or vertical mounting
  • Built-in threaded standoffs with the required standoff kit 320-3290 (sold separately) provide a sturdy foundation for mounting the LBB-3v2 or KAB-BE in either direction
Your Price: $4.98
MSRP: $5.99
Save $1.01 (17%)
It can be quite difficult to install the audio amplifier board into tight spaces such as portable sound applications. To securely mount the KAB boards and improve space efficiency Dayton Audio offers the KAB-AB; an L-type aluminum bracket. This aluminum bracket supports vertical and horizontal mounting configurations to satisfy different installation requirements. With four M 3 screw lock standoffs, this amplifier board installs easily on the bracket with four included security screws. Two M 3 holes and seven slots give you the versatility to mount the L-type bracket to your project as needed.
Dimensions: 5" L x 3" W x 1" H.
ModelKAB-AB
Part Number325-114
UPC848791002588
Weight0.2
Board TypePanels & Mounting Acc.
