  • Mogami W2549 Neglex Long Run Microphone Signal Cable 328 ft. (100m)
Mogami
Part #103-1014
Mogami
Part #103-1014
Model: 2549
W2549 Neglex microphone cable by Mogami is designed to preserve your signal while rejecting noise. 2549 is indicated where extended high frequencies are required, and for long cable runs. Two 22 AWG conductors plus a served (spiral) copper shield are covered by a 0.236" PVC jacket which is rugged enough for the road, but very easy to work with.
  • Transparent sound, excellent noise rejection
  • PVC jacket is easy to handle & extremely durable
  • 2 x 22 AWG conductors
  • Easy to work with 0.236" O.D.
  • Made in Japan
Your Price: $287.98
MSRP: $389.99
Save $102.01 (26%)
7In Stock
Mogami's W2549 microphone cable features heavier conductors for longer cable runs, and is also excellent for applications where higher frequencies may be required. Two 22 AWG conductors are insulated with XLPE (cross-linked polyethylene) for excellent electrical characteristics and reduced shrink-back when soldering. A served (spiral) bare copper shield provides superior sound quality compared to foil or braided shields, and makes for easy termination.
Every time you perform or record, your reputation is on the line. Why take the risk of using substandard cables? Since 1957, Mogami has staked their reputation on every cable they've produced. More and more musicians, recording and broadcast studios, and professional production companies not only use Mogami, they demand it. From Fleetwood Mac to Foo Fighters, from Prince to Pearl Jam, just about any modern recorded music you've ever heard has passed through Mogami cable at some point in its production. Thus, Mogami has positioned themselves as the world's leader in audio cable manufacturing, and earned the right to be called "The Cable of the Pros." Made in Japan.
Specifications: • Conductor size: 22 AWG (0.339 mm²) • Conductor insulation: 0.075" (1.9 mm) polyethylene • Outer jacket size: 0.236" (6 mm) • Outer jacket material: PVC.
BrandMogami
Model2549
Part Number103-1014
UPC801813008845
Weight10.95
Jacket ColorBlack
Wire Gauge22
