  • MTX TP1200 ThunderPro2 12" 2-Way PA Loudspeaker
MTX Audio
Part #245-804
MTX Audio
Part #245-804
Model: TP1200
Designed for mobile DJs, musicians, and loud music fans everywhere, MTX Audio offers the ThunderPro 2 Series of affordable professional PA loudspeakers.
  • Generation 2 X-radial designed horn-loaded tweeter provides uniform sound dispersion and coverage area
  • MDF box covered with durable, aviation grade carpet
  • Reinforced easy grip handles and interlocking corner supports
  • High excursion ported woofer configuration for thundering lows
  • 5-way binding post and 1/4" phone jack speaker inputs offer amplifier hook-up versatility
  • Stand mounting option
Your Price: $169.95
Order in the next 2 hr 7 min to ship today. Details
The MTX TP1200 Thunder Pro2 is built to last with a stainless steel grill and MDF box covered with aviation grade carpet. The ThunderPro 2 speakers have an X-radial design, horn-loaded tweeter for crisper highs paired with the high excursion ported woofer configurations for better low frequency response. Mobility and setup are an ease with a lightweight design and easy grip handles. Reinforced and interlocking corner supports protect during moving and allow cabinets to be stacked when bigger sound is needed. With a smaller size than other pro speaker lines, the ThunderPro 2 speakers have a long throw and wide dispersion. Can also be pole-mounted to raise the sound stage to ear level.
Specifications: • Power handling: 150 watts RMS/300 watts peak • Impedance: 4 ohms • Frequency response: 39 Hz - 20 kHz • Crossover frequency: 2.5 kHz • Sensitivity: 91.4 dB 1W/1m • Dimensions: 24-3/4" H x 15-1/4" W x 12-3/4" D.
BrandMTX Audio
ModelTP1200
Part Number245-804
UPC715442631339
Weight40.95
ConfigurationFull-Range PA Speaker
Speaker TypePassive / Unpowered
Woofer Size12"
