  • MTX Monitor 5i 5-1/4" 2-Way Bookshelf Speaker Pair
MTX Audio
Part #302-019
MTX Audio
Part #302-019
MTX's power-packed Monitor 5i will surprise you with a sound that is larger than what would be expected from a speaker this size. A ported enclosure design squeezes out every last drop of bass from the 5-1/4" polypropylene woofer.
  • Great bang-for-the-buck value
  • 5-1/4" poly woofer with rubber surround ensures smooth transition from lows into midrange
  • 1/2" balanced dome tweeter provides top-end sparkle
  • Bass reflex enclosure for deep, accurate bass
Your Price: $129.95
MTX's power-packed Monitor 5i will surprise you with a sound that is larger than what would be expected from a speaker this size. A ported enclosure design squeezes out every last drop of bass from the 5-1/4" polypropylene woofer. Incredible imaging results from the use of a 1/2" balanced dome tweeter. At home in a surround sound setup or as a dorm room speaker, the diminutive size allows for unlimited placement options. Best of all, it fits your budget. Sold in pairs.
Specifications: • Woofer: 5-1/4" poly • Tweeter: 12 mm dome • Frequency response: 48-20,000 Hz • Impedance: 8 ohms • SPL: 88 dB 2.83V/1m • Dimensions: 10-1/2" x 6-1/2" x 8-1/2" • 6 lbs.
BrandMTX Audio
ModelMonitor 5i
Part Number302-019
UPC715442650422
Unit of MeasurePairs
Weight12
ColorBlack
Configuration2-way
Input Rating8 ohm
Woofer Diameter5.25"
