  • MTX Monitor 60i Dual 6-1/2" 2-Way MTM Bookshelf Speaker Pair
MTX Audio
Part #302-017
MTX Audio
Part #302-017
Model: Monitor 60i
As one of four models in the completely redesigned Monitor series, the MTX Monitor 60i bookshelf speaker uses its dual 6-1/2" woofers to deliver far more dynamics and output than what conventional single driver boxes can manage. "Timbre-matched voicing" ensures the Monitor 60i's voicing matches the rest of the MTX Monitor Series loudspeakers.
  • D'Appolito design controls dispersion and increases output compared to single driver systems
  • Voice-matched for consistency throughout the entire Monitor family
  • Dual 6-1/2" polypropylene woofers with rubber surround supply solid bass
  • 19 mm PEI dome tweeter adds the brilliance and accuracy for which the Monitor Series speakers are known
Your Price: $249.95
The MTX Monitor 60i power-packed bookshelf speaker is a great addition to any high performance system. Engineered from the ground up for accurate sound and exceptional imaging in real world situations, the Monitor 60i is in line with the high standards of performance expected from MTX. The Monitor 60i produces superior sound quality from a surprisingly small source. It features two 6-1/2" polypropylene woofers with rubber surrounds and a 19 mm PEI dome tweeter in a D'Appolito array, a unique design for a high output bookshelf. This arrangement reduces the unwanted reflective sound from floors and ceilings with a controlled vertical dispersion. Plus, with the dual woofers in a common, vented enclosure, the Monitor 60i has a much lower bass extension, higher power handling, and higher efficiency than single woofer bookshelf speakers. Sold in pairs.
Specifications: • Woofer: 6-1/2" poly • Tweeter: 19 mm dome • Frequency response: 42-20,000 Hz • Impedance: 8 ohms • SPL: 92 dB 2.83V/1m • Dimensions: 17-5/8" x 7-1/2" x 11-7/8" • 14.5 lbs.
BrandMTX Audio
ModelMonitor 60i
Part Number302-017
UPC715442650385
Unit of MeasurePairs
Weight30
ColorBlack
Configuration2-way MTM
Input Rating8 ohm
Woofer Diameter6.5"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
