CLEARANCE Lavolta 3CL20B 20-Piece RGB 5050 SMD 3 LED Module IP67 Waterproof 9 ft. Light Strip - Black
- Aggressive adhesive peel and stick wide strips on each module for quick mounting
- A hole on each side of the module provides a lasting hold with optional screws
- 2.7" flexible 4-conductor wire separates each 3 RGB LED module for adjustable mounting
- 20 modules have the ability to stay stuck together for back lighting signs or separate for a 9 ft. run
- IP 67 waterproof rating and 12 VDC power requirement make the LED modules ideal for use on watercrafts and off-road vehicles
216In Stock
We'll send you an email when Lavolta 3CL20B 20-Piece RGB 5050 SMD 3 LED Module IP67 Waterproof 9 ft. Light Strip - Black is back in stock or available for preorder.
