  • Lavolta IR-BT1 40-Key RGB LED Bluetooth Smart Controller with IR Remote, Music and Timer Function
CLEARANCE Lavolta IR-BT1 40-Key RGB LED Bluetooth Smart Controller with IR Remote, Music and Timer Function
Lavolta
Part #073-1004
Lavolta
Part #073-1004
Model: IR-BT1
Design your custom lighting solution easily using this 40-key LED control unit with IR remote or Bluetooth option. This unique controller/remote combo enables you to adjust color, speed, sound activation, brightness, and use time. The Bluetooth feature adds the ability to use these options and more with your smartphone.
  • Scan the QR code on the controller for a free Bluetooth app for easy smartphone control within 50 ft.
  • Plugs directly into Lavolta and most 4-pin RGB LED light strips and light strip modules
  • Use the built-in playlist in the app or built-in microphones in the controller for music/sound modes
  • Timer feature saves battery power or electricity
  • Works with light strips from 5 to 24 VDC up to 144W
CLEARANCE $5.00
MSRP: $14.99
Save $9.99 (67%)
Order in the next 3 hr 19 min to ship today. Details
214In Stock
Create custom lighting effects with this 40-key IR remote control and LED control unit, that's specifically designed to work with 5-24 VDC 4-pin RGB LED light strips. Adjust brightness, color, fade in/out, flash rate, sound sensitivity, and timer. Supports up to 96 ft. (30m) of 12 VDC, RGB LED 60/m light strips. Other tri-color, common anode LEDs may be used if configured to work with 5 to 24 VDC supply voltages. IR remote control uses a CR2025 battery (included). Requires 5 to 24 VDC power supply (not included). Make sure the power supply meets the requirements of the LED lights. DC input is 2.1 x 5.5 mm tip positive, but still works with most 2.5 x 5.5 mm.
Create and control your LED RGB light strips with a free Bluetooth App by scanning the QR code on the controller. Get more color and timer options with this Bluetooth App and control your LED RGB light strips from up to 50 ft. away. Switch to music mode in the app and create a play list so the sensitivity of the microphones in the controller has nothing to do with the volume of the music.
Specifications: • Voltage input: 5-24 VDC • Voltage output: 5 to 24 VDC determined by your AC/DC power supply (sold separately) • Controller dimensions: 2.5” x 1.5” x 0.5” (62 x 35 x 14 mm) without 4” (100 mm) leads • Power output: Up to 144W • IR wireless remote: 40-keys • Included battery: CR2025 • Remote dimensions: 4.9” x 2.2” x 0.3” (124 x 56 x 7.5 mm).
BrandLavolta
ModelIR-BT1
Part Number073-1004
UPC848864069968
Weight0.2
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
