  • LaVoce WAN123.00 12" Neodymium Woofer 8 Ohm
10 Questions, 21 Answers or
LaVoce
Part #293-719
LaVoce
Part #293-719
Model: WAN123.00
The LaVoce WAN123.00 is an impressive 12" woofer that features a rigid aluminum basket which provides exceptional cooling. The excellent 99 dB sensitivity is perfect for mating to other high-efficiency drivers.
  • FEM optimized Neodymium motor and suspensions
  • Optimized cooling system for reliable performance
  • Impressive 99 dB sensitivity
  • Resonance-free, heavy-duty aluminum basket demonstrates excellent build quality
Your Price: $215.00
MSRP: $320.90
Save $105.90 (33%)
5In Stock
The LaVoce WAN123.00 is an impressive 12" woofer that features a solid cast aluminum basket which provides exceptional cooling. The excellent 99 dB sensitivity is perfect for mating to other high-efficiency drivers. The gasket on this driver allows it to be rear mounted easily, providing additional installation flexibility. To add to the versatility of this driver, the cone has been treated to be waterproof, making it ideal for outdoor cabinets.
BrandLavoce
ModelWAN123.00
Part Number293-719
UPC848864057415
Weight14.95
Nominal Diameter12"
Bolt Circle Diameter11.73
Power Handling (RMS)500 Watts
Frequency Response50 to 3,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)48Hz
DC Resistance (Re)4.8Ω
Voice Coil Inductance (Le)0.7mH
Mechanical Q (Qms)6.2
Electromagnetic Q (Qes)0.28
Total Q (Qts)0.26
Compliance Equivalent Volume (Vas)2.58ft³
Mechanical Compliance of Suspension (Cms)0.17mm/N
BL Product (BL)17.8T·m
Diaphragm Mass Inc. Airload (Mms)61g
Maximum Linear Excursion (Xmax)7mm
Surface Area of Cone (Sd)531cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.40"
Baffle Cutout Diameter11.19"
Depth6.08"
Vented Volume1.5ft³
Vented F351.8Hz
