  • LaVoce WAF154.02 15" Subwoofer 8 Ohm
LaVoce
Part #293-722
LaVoce
Part #293-722
Model: WAF154.02
The LaVoce WAF154.02 is an impressive 15" woofer that features an impressive aluminum basket which provides exceptional cooling. The excellent 97.5 dB sensitivity is perfect for mating to other high-efficiency drivers.
  • FEM optimized Ferrite motor and suspensions
  • Optimized cooling system for reliable performance
  • Large 4" voice coil for improved power handling
  • Resonance-free, heavy-duty aluminum basket demonstrates excellent build quality
Your Price: $239.00
MSRP: $356.72
Save $117.72 (33%)
Only 2 In Stock
The LaVoce WAF154.02 is an impressive 15" woofer that features an impressive aluminum basket which provides exceptional cooling. The excellent 97.5 dB sensitivity is perfect for mating to other high-efficiency drivers. The WAN154.02 also features a double silicone spider for improved linearity. The gasket on this driver allows it to be rear mounted easily, providing additional installation flexibility. To add to the versatility of this driver, the cone has been treated to be waterproof, making it ideal for outdoor cabinets.
BrandLavoce
ModelWAF154.02
Part Number293-722
UPC848864057446
Weight27.7
Nominal Diameter15"
Bolt Circle Diameter14.69
Frequency Response40 to 1,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)40Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.7mH
Mechanical Q (Qms)7.2
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)4.63ft³
Mechanical Compliance of Suspension (Cms)0.1mm/N
BL Product (BL)23.1T·m
Diaphragm Mass Inc. Airload (Mms)148.8g
Maximum Linear Excursion (Xmax)7.9mm
Surface Area of Cone (Sd)830cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.93"
Depth6.8"
Sealed Volume1.5ft³
Sealed F362.1Hz
Vented Volume3.75ft³
Vented F343.6Hz
