  • LaVoce DF10.142LK 1" Polyimide Compression Driver 8 Ohm 4-Bolt
LaVoce
Part #293-758
LaVoce
Part #293-758
Model: DF10.142LK
LaVoce's compact DF10.142LK 1" exit compression driver delivers smooth high frequency response with excellent detail and accuracy. The lightweight 1.4" polyimide diaphragm produces response all the way up to 20,000 Hz with minimal resonances to minimize unwanted peaks and dips. At only 3-1/2" diameter this driver is perfect for designs where space is at a minimum, such as stackable line arrays and mobile audio systems.
  • Compact design allow this driver to be used in tight spaces
  • 1.4" polyimide diaphragm delivers accurate high frequency response up to 20,000 Hz
  • Smooth response allows an easy transition to a midrange driver
  • 1" exit with standard 4-bolt mount for use with many popular horns
Your Price: $59.00
MSRP: $88.06
Save $29.06 (33%)
Only 3 In Stock
When space is a concern but you need high output capability, the compact DF10.142Lk 1" compression driver from LaVoce is a great solution. This driver uses a compact ferrite motor that has been optimized to provide maximum flux with excellent heat dissipation to produce high efficiency and minimal power compression when driven for extended periods. To keep resonances under control and deliver natural response the 1.4" polyimide diaphragm has outstanding damping properties. With a standard 1" throat and 4-bolt mount the DF10.142LK is compatible with many popular horns. The small size and natural response makes this compression driver perfect for use in a variety of dynamic speaker designs such as stackable line arrays, portable DJ systems, and high SPL mobile sound systems.
Specifications: • Power handling: 35 watts RMS with minimum crossover of 2,200 Hz at 12 dB per octave • VCdia: 1.4" • Impedance: 8 ohms • Frequency response: 1,500-20,000 Hz • SPL: 106 dB 1W/1m • Dimensions: 3.5" diameter x 1.6" depth • Net weight: 2 lbs.
BrandLavoce
ModelDF10.142LK
Part Number293-758
UPC848864061535
Weight2.25
Diaphragm MaterialKapton / Polyimide
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)35 Watts
