  • Knock-Down MDF 1.16 ft³ Tower Cabinet
NEW Knock-Down MDF 1.16 ft³ Tower Cabinet
Part #300-5006
Part #300-5006
Build your own tower speaker cabinet in minutes with this CNC-cut cabinet.
  • CNC-cut, acoustically inert MDF panels for precise fit and finish
  • 1.16 cu. ft. internal volume
  • Build your own tower or large format center channel speaker
  • Assembles in minutes
  • Made in the U.S.A.
NEW $89.98
MSRP: $109.99
Save $20.01 (18%)
CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills, perfect for DIYers without expensive tools or access to a woodshop.
During the CNC process, dadoes are cut into the top, bottom, and rear panels to ensure a tight, secure fit that maximizes the gluing surface and making assembly that much easier. This tower cabinet allows you to create your very own front left or right tower speaker... or even a large format center channel speaker! Three included window braces add structural integrity while consuming as little internal volume as possible.
Additionally, users can mount side-firing a woofer (up to 8" maximum is recommended) for a modern 3-way design. The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished cabinet volume: 1.16 cubic feet • External dimensions: 34" H x 8" W x 11" D • Internal dimensions: 32-1/2" H x 6-1/2" W x 9-1/2" D • Made in the U.S.A. • Sold individually.
Part Number300-5006
UPC848864075655
Weight27.75
