  • Knock-Down MDF 0.67 ft³ Subwoofer Cabinet
NEW Knock-Down MDF 0.67 ft³ Subwoofer Cabinet
15 Questions, 33 Answers or
Part #300-5008
Part #300-5008
Build your own computer or surround sound subwoofer with this CNC-cut 12" cube cabinet in minutes.
  • CNC-cut MDF panels for precise fit and finish
  • 0.67 cu. ft. internal volume
  • Build your own compact subwoofer
  • Assembles in minutes
  • Made in the U.S.A.
NEW $46.98
MSRP: $65.99
Save $19.01 (29%)
Order in the next 19 hr 31 min to ship today. Details
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. Perfect for speaker builders and designers without expensive tools or access to a woodshop.
During the CNC process, dadoes are cut into the top, bottom, and rear of the side panels to ensure a secure fit, maximizing the gluing surface and making assembly that much easier. The front baffle features roundovers on each exposed edge for a professional look.
The end result is a subwoofer speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished cabinet volume: 0.67 cubic feet • External dimensions: 12" H x 12" W x 12" D • Internal dimensions: 10.5" H x 10.5" W x 10.5" D • Made in the U.S.A.
Part Number300-5008
UPC848864075662
Weight15.45
