  • Denovo Audio Knock-Down MDF 1.0 cu. ft. Subwoofer Cabinet
CLEARANCE Denovo Audio Knock-Down MDF 1.0 cu. ft. Subwoofer Cabinet
Denovo Audio Inc
Part #300-7085
Denovo Audio Inc
Part #300-7085
No tools? Don't let that stop you from building a beast of a subwoofer. This superior subwoofer cabinet is CNC-machined for precise panels and is specifically built for ease of construction.
  • 1 cubic foot cabinet made of 3/4" MDF panels
  • Double-thick 1-1/2" front baffle
  • Carb 2 compliant material
  • CNC-machined dadoes and a unique bracing system that increases cabinet rigidity
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with rabbeted recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 1.0 cubic feet • External dimensions: 14.25" H x 14.25" W x 15" D • Weight: 29 lbs. • Made in the U.S.A.
BrandDenovo Audio Inc
Part Number300-7085
UPC848864018348
Weight30.45
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE 20%
Shadow Mounts DTS65 Universal Sturdy Desktop Tabletop Entertainment Center TV Monitor Stand Up to 65"
