  • Gorilla Glue 4 oz. Bottle
Gorilla Glue
Part #340-004
Gorilla Glue
Part #340-004
Model: 50004
Gorilla Glue is a versatile, interior/exterior adhesive ideal for most household fixes and building projects: furniture repair, crafts, woodworking, project assembly, general repairs around the house, and let's not forget speaker building projects.
  • Pure polyurethane
  • 100% waterproof
  • Perfect for speaker building
  • Non-toxic
  • Bonds just about everything
Your Price: $8.98
MSRP: $9.99
Save $1.01 (10%)
Gorilla Glue is a versatile, interior/exterior adhesive ideal for most household fixes and building projects: furniture repair, crafts, woodworking, project assembly, general repairs around the house, and let's not forget speaker building projects. Use Gorilla Glue to bond wood, stone, metal, ceramic, brick, foam board, fiberglass, and much, much more. It is 100% waterproof and can be used indoors and out. Once it is cured, it is unaffected by changes in temperature, and will not breakdown when exposed to rain or snow. Being a pure polyurethane glue it is strong and versatile. It contains no additives or solvents which provides a much stronger bond and allows different materials to be glued together. Gorilla Glue is the perfect glue for any woodworker. When it dries it leaves an invisible glue line that can be painted or stained. As an added bonus it will not gum up sandpaper or dull cutting tools. It is completely non-toxic when cured and is free from solvents and fillers. Gorilla Glue contains no carcinogens and does not release fumes in its liquid state or when dry.
Specifications: • Waterproof: 100%, passes ANSI/HPVA HP-I-2000 Types 1 and 2 (waterproof) • Working time: 20 minutes • Acidic level: Neutral pH • Operating temperature: 40 - 130°F.
BrandGorilla Glue
Model50004
Part Number340-004
UPC052427500045
Weight0.35
