  • Shadow Mounts DTS65 Universal Sturdy Desktop Tabletop Entertainment Center TV Monitor Stand Up to 65"
Shadow Mounts
Part #182-413
Shadow Mounts
Part #182-413
Model: DTS65
Change the way you view television. Remove the simple and outdated plastic stands that come with your display, or return your wall mounted TV to eye level with Shadow Mounts DTS65 Tabletop TV Stand. The mount has a sleek, small footprint, low profile design that works with displays up to 65" and 200x200 to 600x400 VESA patterns. DTS65's small but stable 18.9" x 10.24" x 0.31" base fits on almost any entertainment center, table, desk, or dresser. The tempered glass adds a classy look to any room.
  • Adjustable height from 12.98" x 17.71" provides room for soundbars, cable/satellite boxes, and other devices under the display if needed
  • 18.9" x 10.24" dark tinted, durable 0.31" thick tempered glass base fits on most home theater furniture and adds an elegant look to any room
  • High-quality, black matte finish brackets for a more modern look
  • Fits any TV with 200 x 200 to 600 x 400 VESA pattern
  • Holds up to 80 lbs. and TVs from 37" to 65" comfortably
  • Includes hardware to fit multiple size holes for most TVs
Your Price: $19.98
MSRP: $49.99
Save $30.01 (60%)
Small Footprint, Low Profile Modern Looking TV Stand Mount
Built with quality in mind, the DTS65 is a new way to mount your TV. The DTS65 supports most displays up to 65" and weighing less than 80 lbs., and the unique design of its universal mounting brackets mean compatibility is almost guaranteed. For precise compatibility, simply check your display’s VESA pattern against the VESA range 200 x 200 to 600 x 400. If your display’s VESA matches or falls within this range, then your display is compatible. It’s that easy. Once the VESA pattern is matched to the two vertical brackets, determine how much space you want to expose under the TV for a soundbar or cable/satellite box. The vertical pole has multiple holes that enable you to adjust the height of the horizontal bracket. Larger displays must you the holes towards the top of the vertical pole.
The DTS65 is a sleek alternative to wall mounts or too wide/unattractive plastic stands the come with new TVs. Its stylish look fits with just about any design space or home theater furniture. A high-quality black matte finish gives a modern yet minimalistic look that won’t detract from your set up, making your TV the focal point of the area, all while hiding the hardware. The DTS65 is also perfect for those people who have upgraded their wall mount TVs to a larger size and have thrown away the included stand that came with their smaller/older display. Use that smaller display in another room since the DTS65 fits almost any size TV 37" to 65", and its small but stable 18.9" x 10.24" x 0.31" base fits on almost any table, entertainment center, desk, or dresser. The durable, 0.31" thick tempered glass base adds a classy look to any room.
DTS65's quality materials, guarantee that it will not bend or snap under pressure, ensuring your display’s security. Included in the box is an easy to understand manual, complete with demonstrative images that show you the exact steps needed to achieve your perfect viewing experience. For convenience, we have also included multiple screw sizes to ensure compatibility with a wide range of display types.
  • Display compatibility: 37" to 65"
  • Max load: 80 lbs.
  • VESA patterns: 200x200 to 600x400
  • Tempered glass shelf dimensions: 18.9" x 10.24" x 0.31" (480 x 260 x 8 mm)
  • Steel pole: 3.16" x 1.58" x 18.89" (80 x 40 x 480 mm)
  • Height adjustment: 12.98" to 17.71" (330 mm to 450 mm)
  • Horizontal bracket dimensions: 25.5" x 5.25" x 0.43" (648 x 134 x 11 mm)
  • Vertical brackets dimensions: 16.62" x 1.25" x 0.68" (423 x 32 x 17.5 mm)
BrandShadow Mounts
ModelDTS65
Part Number182-413
UPC848864071992
Weight12.4
Mount StyleDesk / Tabletop
Mount TypeFixed
TV Capacity40" to 49"-50" to 59"-60" to 69"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE 20%
