  • Parts Express IEC AC Power Jack Chassis Mount
Part #090-442
Part #090-442
This IEC power jack is perfect for replacement, DIY projects or converting older equipment, so they can be used with IEC style power cords. It is constructed out of high temperature, impact resistant UL94V-0 plastic.
Your Price: $1.60
MSRP: $1.99
Save $0.39 (20%)
Quantity:Qty: 1-9 $1.60/ea
Quantity:Qty: 10+$1.44/ea
471In Stock
This IEC power jack is perfect for replacement, DIY projects or converting older equipment, so they can be used with IEC style power cords. It is constructed out of high temperature, impact resistant UL94V-0 plastic. The heavy gauge contacts are made of nickel plated brass and will accept solder or .187" quick disconnects. Contact rating: 10A, 250VAC. Overall dimensions: 2" x 7/8". Cut out dimensions: 1-1/16" x 3/4". Mounting depth with terminals 0.83" (21mm). UL and CSA listed.
Part Number090-442
UPC844632005152
Weight0.1
ConfigurationIEC
Current Rating10A
Power Connector TypeChassis / Panel Mount
