  • Parts Express IEC AC Power Jack Chassis Mount with 10A Fuse Holder
Part #090-443
Part #090-443
Perfect for DIY projects or converting older equipment for use with IEC type power cords. The GMA fuse holder can handle up to 10A and has space for a spare fuse.
Your Price: $2.35
MSRP: $2.99
Save $0.64 (21%)
Quantity:Qty: 1-9 $2.35/ea
Quantity:Qty: 10+$2.12/ea
Order in the next 5 hr 45 min to ship today. Details
441In Stock
Perfect for DIY projects or converting older equipment for use with IEC type power cords. The GMA fuse holder can handle up to 10A and has space for a spare fuse. The "snap-in" style housing is constructed of high temperature, impact resistant UL94V-0 plastic. The heavy gauge contacts are made of nickel plated brass and will accept solder or .187" quick disconnects. Contact rating: 10A, 250VAC. Fuse type: GMA (5 mm x 20 mm). Overall dimensions: 30 mm (W) x 33 mm (H). Cut out dimensions: 27 mm (W) x 31.5 mm (H). Mounting depth with terminals: 23mm. Panel material thickness: 0.8 mm-1.8 mm. UL and CSA listed. Fuses sold separately.
Part Number090-443
UPC844632005169
Weight0.1
ConfigurationIEC
Current Rating10A
Power Connector TypeChassis / Panel Mount
