  • HiVi B3S 3" Shielded Aluminum Driver Square Frame
HiVi
Part #297-427
HiVi
Part #297-427
Model: B3S
Magnesium/aluminum alloy concave cones and square frames are the distinguishing features of the BS series. The B3S 3" full-range speaker's magnetically shielded design allows use in center channel and other multimedia applications.
Your Price: $12.49
MSRP: $16.99
Save $4.50 (26%)
Quantity:Qty: 1-3 $12.49/ea
Quantity:Qty: 4-9 $11.87/ea
Quantity:Qty: 10+$11.24/ea
147In Stock
Magnesium/aluminum alloy concave cones and square frames are the distinguishing features of the BS series. The B3S 3" full-range speaker's magnetically shielded design allows use in center channel and other multimedia applications. HiVi's Symmetric Motor Drive (SMD) technology reduces the voice coil's inductance modulation and back EMF, thereby improving the speaker's controllabilty and achieving impressively low distortion. Stamped steel frame and rubber surround. These drivers are capable of covering a wide portion of the audio spectrum, and are easy to install without the need for cutting complicated driver recesses.
BrandHiVi
ModelB3S
Part Number297-427
UPC844632022999
Weight1.5
Nominal Diameter3"
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response300 to 15,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)100Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)3.75
Electromagnetic Q (Qes)1.15
Total Q (Qts)0.88
Compliance Equivalent Volume (Vas)0.04ft³
Mechanical Compliance of Suspension (Cms)0.99mm/N
BL Product (BL)3.06T·m
Diaphragm Mass Inc. Airload (Mms)2.6g
Surface Area of Cone (Sd)30cm²
Cone MaterialAluminum / Magnesium
Voice Coil Wire MaterialCCA
Overall Outside Diameter3"
Baffle Cutout Diameter2.75"
Depth2.13"
Sealed Volume0.1ft³
Sealed F398.4Hz
Vented Volume0.2ft³
Vented F374Hz
