  • 3M Super 77 Multipurpose Spray Adhesive Glue 24 fl. oz. / 16.7 oz. Net Wt.
3M
Part #340-255
3M
Part #340-255
Model: Super 77
3M Super 77 high tack, fast drying transparent adhesive is perfect for speaker building and audio projects, as well as everything from crafts and models to home improvement, repair projects, and hobbies.
  • Great for attaching cabinet carpet, laminates, veneers, and grill cloth
  • Wide 3" spray nozzle covers more surface area in less time
  • Adheres to a variety of materials for multiple applications
  • High-strength initial grab, dries quickly, provides professional looking results
Your Price: $17.38
MSRP: $46.99
Save $29.61 (63%)
Order in the next 12 hr 44 min to ship today. Details
Only 13 In Stock
The 3M Super 77 spray formula is a high tack, fast drying transparent spray adhesive that permanently attaches a variety of materials to wood, metal, painted, and unpainted surfaces. 3M Super 77 features high initial grab with sufficient time to position materials before it has fully set up, and its wide 3" spray pattern actuator allows you to cover a large surface area with adhesive faster. 16.7 oz. net wt., contains 24 fl. oz. Be sure to use only in a well ventilated area.
Usage Tips
In order to obtain the best results with your 3M Super 77, be sure surfaces are free from dirt, grease, and moisture. Shake your Super 77 can well just before application, to ensure a strong hold. Align the arrow on the nozzle with the dot on the top of the can. Keep the spray can upright between 6"-8" away from the surface you are spraying. It's recommended to spray a test pattern on a piece of scrap away from the project surfaces. Spray a light uniform coat, keeping the can moving from side to side. Wait 30 seconds before securing the bond between materials. Average coverage is about 185 sq. ft. To help alleviate clogged nozzles and save your adhesive for later use, invert can and spray until adhesive stops before storing.
Brand3M
ModelSuper 77
Part Number340-255
UPC076308913120
Weight1.4062
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
