  • Goldwood GW-S650/8 6-1/2" Poly Cone Woofer 8 Ohm
Goldwood
Part #290-309
Goldwood
Part #290-309
Model: GW-S650/8
These silver polymer cone woofers feature a cosmetic stamped steel frame, vented and bumped back plate, and high-quality rubber surround. The relatively shallow profile, polymer construction, and T/S parameters make them great for sealed, free air, or in wall use.
  • Modern looking silver colored polypropylene cone
  • Vented pole piece keeps voice coil cool
  • Ample mechanical excursion with a raised spider and bumped back plate
  • Moisture resistant poly cone and rubber surround
Your Price: $20.78
MSRP: $33.99
Save $13.21 (39%)
Order in the next 19 hr 15 min to ship today. Details
BrandGoldwood
ModelGW-S650/8
Part Number290-309
UPC643420100525
Weight2.9
Nominal Diameter6-1/2"
Power Handling (RMS)85 Watts
Power Handling (MAX)170 Watts
Frequency Response35 to 5,000Hz
Sensitivity85.7dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)56.2Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)3.49
Electromagnetic Q (Qes)1.09
Total Q (Qts)0.83
Compliance Equivalent Volume (Vas)0.46ft³
Mechanical Compliance of Suspension (Cms)0.48mm/N
BL Product (BL)6.17T·m
Diaphragm Mass Inc. Airload (Mms)16.8g
Surface Area of Cone (Sd)139.7cm²
Cone MaterialPoly
Overall Outside Diameter7"
Baffle Cutout Diameter5.875"
Depth2.875"
Sealed Volume0.65ft³
Sealed F359.9Hz
Vented Volume1.25ft³
Vented F341.6Hz
