  • Goldwood GW-S525/8 5-1/4" Poly Cone Woofer 8 Ohm
Goldwood
Part #290-302
Goldwood
Part #290-302
Model: GW-S525/8
These silver polymer cone woofers feature a cosmetic stamped steel frame, vented and bumped back plate, and high-quality rubber surround. The relatively shallow profile, polymer construction, and T/S parameters make them great for sealed, free air, or in wall use.
  • Poly cone and rubber surround is ideal for harsh environments
  • Vented pole piece improves power handling
  • Cosmetic frame looks good without countersinking
  • Bumped back plate increases mechanical excursion
Your Price: $15.18
MSRP: $24.99
Save $9.81 (39%)
Order in the next 2 hr 25 min to ship today. Details
BrandGoldwood
ModelGW-S525/8
Part Number290-302
UPC643420100501
Weight1.6
Nominal Diameter5-1/2"
Power Handling (RMS)70 Watts
Power Handling (MAX)130 Watts
Frequency Response50 to 5,500Hz
Sensitivity84.7dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)81.1Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)2.87
Electromagnetic Q (Qes)1.18
Total Q (Qts)0.84
Compliance Equivalent Volume (Vas)0.13ft³
Mechanical Compliance of Suspension (Cms)0.4mm/N
BL Product (BL)5.41T·m
Diaphragm Mass Inc. Airload (Mms)9.7g
Surface Area of Cone (Sd)82.29cm²
Cone MaterialPoly
Overall Outside Diameter5.625"
Baffle Cutout Diameter4.56"
Depth2.5"
Sealed Volume0.25ft³
Sealed F383.3Hz
Vented Volume0.5ft³
Vented F359.9Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
