  • Goldwood GW-8PC-8 8" Delmar Series Heavy Duty Woofer 8 Ohm
Goldwood
Part #290-314
Goldwood
Part #290-314
Model: GW-8PC-30-8
The Heavy Duty Delmar Series is available in 4 ohm and 8 ohm versions for automotive and home audio applications. The woofers feature aluminum die-cast frames, knurled and gold-plated binding posts, rubber surrounds, and vented pole pieces with bumped back plates.
Your Price: $54.98
MSRP: $71.99
Save $17.01 (24%)
Quantity:Qty: 1-3 $54.98/ea
Quantity:Qty: 4-9 $52.23/ea
Quantity:Qty: 10+$49.48/ea
Order in the next 3 hr 51 min to ship today. Details
The Heavy Duty Delmar Series is available in 4 ohm and 8 ohm versions for automotive and home audio applications. The woofers handle the most powerful of amplifiers while maintaining sonic excellence. They feature aluminum die-cast frames, knurled and gold-plated binding posts, rubber surrounds, and vented pole pieces with bumped back plates.
BrandGoldwood
ModelGW-8PC-30-8
Part Number290-314
UPC643420100181
Weight5.2
Nominal Diameter8"
Power Handling (RMS)160 Watts
Power Handling (MAX)330 Watts
Frequency Response25 to 2,800Hz
Sensitivity88.2dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)55Hz
DC Resistance (Re)7.24Ω
Voice Coil Inductance (Le)0.98mH
Mechanical Q (Qms)5.89
Electromagnetic Q (Qes)0.62
Total Q (Qts)0.56
Compliance Equivalent Volume (Vas)0.51ft³
Mechanical Compliance of Suspension (Cms)0.24mm/N
BL Product (BL)11.78T·m
Diaphragm Mass Inc. Airload (Mms)34.26g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)205.9cm²
Cone MaterialPoly
Overall Outside Diameter8.25"
Baffle Cutout Diameter7.125"
Depth3.69"
Sealed Volume0.5ft³
Sealed F359Hz
Vented Volume1ft³
Vented F345.4Hz
