  • Goldwood GW-10PC-4 10" Heavy Duty Woofer 4 Ohm
Goldwood
Part #290-322
Goldwood
Part #290-322
Model: GW-10PC-4
The Heavy Duty PC Series is available in 4 ohm and 8 ohm versions for wiring flexibility making these perfect replacement drivers for many home audio applications. The woofers feature aluminum die-cast frames, knurled and gold-plated binding posts, rubber surrounds, and vented pole pieces with bumped back plates.
Your Price: $59.98
MSRP: $90.99
Save $31.01 (34%)
Order in the next 5 hr 2 min to ship today. Details
The Heavy Duty PC Series is available in 4 ohm and 8 ohm versions for wiring flexibility making these perfect replacement drivers for many home audio applications. The woofers handle the most powerful of amplifiers while maintaining sonic excellence. They feature aluminum die-cast frames, knurled and gold-plated binding posts, rubber surrounds, and vented pole pieces with bumped back plates.
BrandGoldwood
ModelGW-10PC-4
Part Number290-322
UPC643420100198
Weight7.4
Nominal Diameter10"
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Frequency Response25 to 3,000Hz
Sensitivity92.7dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)43.1Hz
DC Resistance (Re)3.8Ω
Voice Coil Inductance (Le)1.4mH
Mechanical Q (Qms)4.25
Electromagnetic Q (Qes)0.45
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)1.15ft³
Mechanical Compliance of Suspension (Cms)0.2mm/N
BL Product (BL)12.71T·m
Diaphragm Mass Inc. Airload (Mms)69.7g
Surface Area of Cone (Sd)344.9cm²
Cone MaterialPoly
Overall Outside Diameter10.25"
Baffle Cutout Diameter9.125"
Depth4.375"
Sealed Volume0.47ft³
Sealed F384.6Hz
Vented Volume1.7ft³
Vented F342.7Hz
MONSTER DEAL
OF THE WEEK
$34.98 EACH
SAVE 22%
Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
