  • GRS PT2522-4 3-1/2" Planar Tweeter 4 Ohm
GRS
Part #272-122
GRS
Part #272-122
Model: PT2522-4
With a low mass diaphragm and powerful motor, the GRS PT2522-4 planar back tweeter delivers high efficiency output with excellent transient response. The open back construction produces true dipole radiation which is ideal for use in open baffle designs. Smooth frequency response and low distortion gives the PT2522-4 an incredibly natural but dynamic sound.
  • Extremely low mass diaphragm provides excellent transient response and accuracy
  • Large diaphragm produces high efficiency and wide bandwidth
  • Remarkably flat response even at 30 degrees off axis
  • Open back delivers true dipole radiation for use in open baffle designs
  • Linear impedance simplifies crossover design
  • Shallow mounting depth for use in low profile designs
  • Custom mounting faceplate available
Your Price: $41.98
MSRP: $51.99
Save $10.01 (19%)
Quantity:Qty: 1-3 $41.98/ea
Quantity:Qty: 4+$37.98/ea
Order in the next 0 hr 34 min to ship today. Details
Designed to deliver high efficiency with extremely smooth response.
The PT2522-4 is a perfect choice for use as a drop-in replacement in existing systems or for use in new designs where low distortion and accurate response is needed. The open-back design gives this tweeter true dipole radiation making it the perfect choice for use in open baffle speaker designs.
Key Specs:
  • Tweeter Type: Planar Magnetic
  • Power Handling (RMS): 20 Watts
  • Power Handling (MAX): 40 Watts
  • Impedance:
  • Frequency Response: 800 - 20,000 Hz
  • Sensitivity: 94dB 2.83V/1m
  • Diaphragm Material: Polyethylene Naphthalate
Full SpecificationsManual
Frequency Response & Impedance
Thanks to a lightweight damped Polyethylene Naphthalate film diaphragm that is driven by 6 powerful neodymium magnets in a push-pull arrangement, this driver is capable of incredible transient response and low distortion. The linear 3.4 ohm impedance makes crossover design simple and minimizes the number of components required to achieve your required roll off.
Optional Faceplate Available
Add the final touches to any build that uses the PT2522-4 with the optional faceplate! When the tweeter is attached to the faceplate, the resulting shape is easier to flush mount into your speaker baffle, creating a clean aesthetic and reducing diffraction.
Buy Now!
Shop all GRS Planar Tweeters and Faceplates
GRS Planar Tweeters provide great transients, and frequency response at the fantastic value you expect from GRS
GRS PT2522C-4
Nominal Impedance: 4ohm
Frequency Response: 800-20kHz
Buy Now
GRS PT6825-8
Nominal Impedance: 8ohm
Frequency Response: 250-20kHz
Buy Now
GRS PT6816-8
Frequency Response: 320-20kHz
Buy Now
GRS PT5010-8
Frequency Response: 200-8kHz
Buy Now
GRS PT2522-FP Face Plate for PT2522-4 and PT2522C-4
Buy Now
GRS PT6825-FP Face Plate for PT6825-8 Planar Tweeter
Buy Now
GRS PT6816-FP Face Plate for PT6816-8 Planar Tweeter
Buy Now
GRS PT5010-FP Face Plate for PT5010-8 Planar Tweeter
Buy Now
BrandGRS
ModelPT2522-4
Part Number272-122
UPC848864061214
Weight0.35
Cutout Diameter2.87" x 2.3
Tweeter TypePlanar
Power Handling (RMS)20 Watts
Frequency Response800 to 20,000Hz
Sensitivity93dB 2.83V/1m
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)0.01mH
Mechanical Q (Qms)4.6
Total Q (Qts)4.46
Overall Outside Diameter3.5" x 2.66"
Depth0.4"
