  • Flight 90 FL24G309 24 VDC 92 x 25mm Fan 2700 RPM
BUYOUT Flight 90 FL24G309 24 VDC 92 x 25mm Fan 2700 RPM
Factory Buyouts
Part #259-2026
Factory Buyouts
Part #259-2026
Model: FL24G309
Extend the life of your electronics economically by using this 92 mm x 25 mm 24 VDC micro cooling fan.
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
  • 12" tinned lead wires for convenience
BUYOUT $1.97
MSRP: $10.00
Save $8.03 (80%)
Order in the next 4 hr 51 min to ship today. Details
405In Stock
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. This economical cooling fan is a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. This fan comes with tinned 12" lead wire for quick installation
Specifications: • Operating voltage: 24 VDC • Power: 2 watts • Speed: 2700 RPM • Dimensions (W x H x D): 92 x 92 x 25 mm.
BrandFactory Buyouts
ModelFL24G309
Part Number259-2026
UPC848864066059
Weight0.3
Operating Voltage24 VDCV
Size92
