  • FaitalPRO 4FE35 4" Professional Full-Range Woofer 16 Ohm
FaitalPRO
Part #294-1125
FaitalPRO
Part #294-1125
Model: 4FE35
FaitalPRO's do-it-all 4FE35 ferrite 4" full-range speaker has high sensitivity and flat frequency response. Perfect for use in pro, home, and car audio applications.
  • Ferrite version of the 4FE32 full-range woofer
  • Strong ceramic ferrite motor
  • Superb off-axis frequency response and handles up to 60 watts program power
  • Copper cap in the motor for reduced distortion
  • Made in Italy
Your Price: $32.00
Only 2 In Stock
More due any day
FaitalPRO's 4FE35 4" professional woofer has exceptionally flat response from 90 Hz to 17,000 Hz, both on and off-axis, and features a 91 dB sensitivity due to a powerful ferrite magnet. Distortion is reduced through the use of a copper cap to create a demodulation circuit in the motor.
Great for use in compact professional line array speakers, the 4FE35 is also right at home in home audio, personal audio, and car audio applications. It's also ideal for fixed installation applications as a midbass, midrange, or full-range speaker. Made in Italy.
BrandFaitalPRO
Model4FE35
Part Number294-1125
UPC848864011127
Weight1.26
Nominal Diameter4"
Bolt Circle Diameter4.54
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Impedance16Ω
Frequency Response90 to 20,000Hz
Sensitivity91dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)100Hz
DC Resistance (Re)12.3Ω
Voice Coil Inductance (Le)0.1mH
Mechanical Q (Qms)3.84
Electromagnetic Q (Qes)1.67
Total Q (Qts)1.16
Compliance Equivalent Volume (Vas)0.07ft³
Mechanical Compliance of Suspension (Cms)0.64mm/N
Diaphragm Mass Inc. Airload (Mms)4g
Maximum Linear Excursion (Xmax)1.83mm
Surface Area of Cone (Sd)48cm²
Cone MaterialPaper
Overall Outside Diameter5.11" (mounting tabs), 3.96"
Baffle Cutout Diameter3.52"
Depth2.3"
Sealed Volume0.09ft³
Sealed F397Hz
