  • Eminence Kappa-15LFA 15" Low Frequency Driver 8 Ohm
Eminence Speaker
Part #290-460
Eminence Speaker
Part #290-460
Model: Kappa-15LFA
The Eminence Kappa-15LFA 15" low frequency speaker is recommended for professional audio in a vented mid-bass or bass enclosure; also suitable for bass guitar.
  • Paper cone and Kapton coil former
  • Polyamide-imide coated copper voice coil
  • Ferrite magnet
  • Vented pole piece and pressed steel basket
  • Cloth accordian surround
  • Direct Replacement for Mackie SWA1501
  • Replaces EAW FR153Z
Your Price: $194.99
MSRP: $239.99
Save $45.00 (19%)
Order in the next 2 hr 2 min to ship today. Details
Only 2 In Stock
More due any day
The Eminence Kappa-15LFA 15" low frequency speaker is recommended for professional audio in a vented mid-bass or bass enclosure; also suitable for bass guitar. Eminence LF models are specifically designed with extended Xmax to deliver more bass than standard models and provide a "true woofer" for three-way applications. Made in the USA. 7-year manufacturer's warranty!
BrandEminence Speaker
ModelKappa-15LFA
Part Number290-460
UPC876358000319
Weight22.25
Nominal Diameter15"
Power Handling (RMS)600 Watts
Frequency Response38 to 2,700Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)39Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)1.27mH
Mechanical Q (Qms)6.08
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)5.62ft³
Mechanical Compliance of Suspension (Cms)0.15mm/N
BL Product (BL)18.6T·m
Diaphragm Mass Inc. Airload (Mms)105g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)856.3cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter15.169"
Baffle Cutout Diameter13.87"
Depth6.38"
Sealed Volume1.75ft³
Sealed F381.5Hz
Vented Volume4ft³
Vented F345.2Hz
