  • PRV Audio 15W1000v2 15" Professional Woofer 8 Ohm
PRV Audio
Part #294-2743
PRV Audio
Part #294-2743
Model: 15W1000v2
The 15W1000v2 15" 8 ohm driver from PRV Audio features a water resistant cone making this woofer the ideal choice for high efficiency outdoor systems. The 3" high temperature voice coil has sufficient ventilation, thanks to the vented back plate, allowing continuous power handling of up to 500 watts.
  • 97 dB sensitivity and 500 watt power handling for extreme output levels
  • 40 to 4,000 Hz response makes this driver suitable for two-way or three-way systems
  • Water resistant cone treatment for outdoor use
  • Large flat spider and multi-roll surround allow for 4.5 mm of excursion
Your Price: $89.91
MSRP: $112.39
Save $22.48 (20%)
Order in the next 5 hr 39 min to ship today. Details
7In Stock
PRV Audio's 15W1000v2 15" professional 8 ohm woofer's reinforced paper cone has been treated to be water resistant making this the perfect driver for outdoor applications. With a vented pole piece and 3" voice coil this driver is capable of up to 500 watts of continuous power, and with 97 dB sensitivity that means exceptionally high output. The reinforced steel frame provides a sturdy support for long life in the difficult pro audio field.
BrandPRV Audio
Model15W1000v2
Part Number294-2743
UPC799928734851
Weight13.5
Nominal Diameter15"
Bolt Circle Diameter14.5
Power Handling (RMS)500 Watts
Frequency Response40 to 4,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)39.56Hz
DC Resistance (Re)5.5Ω
Voice Coil Inductance (Le)1.04mH
Mechanical Q (Qms)25.9
Electromagnetic Q (Qes)0.69
Total Q (Qts)0.68
Compliance Equivalent Volume (Vas)7.29ft³
Mechanical Compliance of Suspension (Cms)0.15mm/N
BL Product (BL)14.54T·m
Diaphragm Mass Inc. Airload (Mms)107.45g
Maximum Linear Excursion (Xmax)6.37mm
Surface Area of Cone (Sd)990cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerAluminum
Overall Outside Diameter15.20"
Baffle Cutout Diameter13.90"
Depth5.82"
Sealed Volume3ft³
Sealed F356.5Hz
Vented Volume4.25ft³
Vented F346.1Hz
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
