  • Eminence FSW4018-8 18" Professional Tour Grade Subwoofer Driver
CLEARANCE Eminence FSW4018-8 18" Professional Tour Grade Subwoofer Driver
Eminence Speaker
Part #290-5658
Eminence Speaker
Part #290-5658
Model: FSW4018-8
Eminence's FSW4018-8 18" tour grade subwoofer is designed to produce extremely high output for extended periods while producing low distortion. The massive ferrite motor has been optimized for maximum excursion capabilities with extensive ventilation allowing the 4" voice coil to handle up to 1,600 watts RMS with minimal power compression.
  • 4" voice coil with ample venting for high power and low compression
  • Massive ferrite motor for high output under any conditions
  • Rigid cast frame will withstand the use and abuse of the pro sound environment
  • X5 pulp paper cone is extremely rigid with excellent damping characteristics
Capable of over 28 mm of peak-to-peak excursion, the Eminence FSW4018-8 18" professional subwoofer is designed to move a lot of air for powerful low frequency output. The FEA optimized ceramic motor assembly includes extensive venting to enable the 4" diameter inside/outside wound voice coil to handle up to 1,600 watts RMS with minimal power compression and low distortion. Supporting the motor is a rigid cast aluminum frame which provides solid mounting points to withstand the beating that can be expected in the professional sound environment. To improve efficiency the FSW4018-8 uses Eminence's rigid but lightweight X5 paper pulp cone. The result is an extremely long throw, rugged, and exceptionally high power handling driver with top notch performance that is designed to handle everything you can throw at it.
Eminence was founded during the days when American Muscle ruled the road. There was no replacement for displacement, and for those of us in the professional audio industry, that statement still holds true. Professional audio is experiencing staggering growth. In anticipation of that growth, Eminence charged thier engineering team to design the best professional audio loudspeakers in the world. We insisted that they beat the performance and durability of every competitor.
The Eminence family of TOUR GRADE loudspeakers, designed and assembled in the USA, represents maximum power handling, maximum displacement, maximum SPL, and unequaled reliability. Advanced measurement systems and FEA optimization tools were implemented on this next generation of subwoofers.
BrandEminence Speaker
ModelFSW4018-8
Part Number290-5658
UPC876358004270
Weight38.7
Nominal Diameter18"
Power Handling (RMS)1600 Watts
Power Handling (MAX)3200 Watts
Frequency Response28 to 1,500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)38Hz
DC Resistance (Re)5.3Ω
Voice Coil Inductance (Le)1.5mH
Mechanical Q (Qms)22.89
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)5.08ft³
Mechanical Compliance of Suspension (Cms)0.07mm/N
BL Product (BL)27.97T·m
Diaphragm Mass Inc. Airload (Mms)240g
Maximum Linear Excursion (Xmax)14.1mm
Surface Area of Cone (Sd)1217cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter18.13"
Baffle Cutout Diameter16.60"
Depth9.42"
Sealed Volume3ft³
Sealed F379Hz
Vented Volume5ft³
Vented F338.3Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
