  • ETRI 642DH1LP11000 40 x 20mm 12 VDC Cooling Fan 1.8W 6000 RPM
BUYOUT ETRI 642DH1LP11000 40 x 20mm 12 VDC Cooling Fan 1.8W 6000 RPM
Factory Buyouts
Part #259-2012
Factory Buyouts
Part #259-2012
Model: 642DH1LP11000
Extend the life of your electronics economically by using this 40 mm x 20 mm micro cooling fan, and its small size fits into the tiniest of spaces.
  • Requires only 12 VDC 150 mA
  • 40 mm x 40 mm x 20 mm size fits it into small places
  • 12" wire lead for convenience
BUYOUT $0.97
MSRP: $8.00
Save $7.03 (88%)
Order in the next 4 hr 52 min to ship today. Details
1705In Stock
The ETRI 642DH1LP11000 40 x 20mm fan fits into areas you never thought possible for a cooling device. Now you can build a miniature amplifier using a smaller case, because the external size only needs to fit a 40 mm fan. The fan's micro size, only 20 mm deep, reduces the amount of internal space required. This size also makes it a great replacement for fans inside portable hard drives and power inverters.
Thanks to the fan's 12 VDC power requirement, portability is an option. You can use this fan in the car to keep air flowing around your amp or in-dash DVD receiver. Various sizes of 12 volt batteries can power the micro fan away from your car. Prevent your paintball visor from fogging up just by installing a small 12 volt battery, micro switch, and this micro fan inside the mask. The uses are endless and it's a cost-effective way to keep your electronics from overheating.
Specifications:• Dimensions (W x H x D): 40 mm x 40 mm x 20 mm • Speed: 6,000 RPM at 12 VDC • Operating voltage: 10.8 - 13.2 • Current draw: 1.8W • Wire length: 12".
BrandFactory Buyouts
Model642DH1LP11000
Part Number259-2012
UPC848864065397
Operating Voltage12 VDCV
Size40
