  • Dayton Audio RSS460HO-4 18" Reference Series HO Subwoofer 4 ohm
Dayton Audio
Part #295-472
Dayton Audio
Part #295-472
Model: RSS460HO-4
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting ring motor for ultra-low distortion
  • 4-layer coil for high power handling
  • Optimized parameters for relatively small enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $399.98
MSRP: $491.99
Save $92.01 (19%)
Quantity:Qty: 1-3 $399.98/ea
Quantity:Qty: 4+$386.98/ea
Order in the next 3 hr 31 min to ship today. Details
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
A knock-down 4.0 cubic foot subwoofer cabinet built specifically for the RSS460HO-4 is available here.
The Dayton Audio RSS460HO-4 is used in the following kits:
Dayton Audio 18" Reference Series HO Subwoofer and Cabinet Bundle
Build the ultimate in high fidelity bass reproduction using this superior subwoofer cabinet and the Dayton Audio RSS460HO-4 Reference Series 18" High Output subwoofer. Save over $40 off original retail price when you purchase this knock-down enclosure and subwoofer package.
ModelRSS460HO-4
Part Number295-472
UPC844632099618
Weight42.35
Nominal Diameter18"
Power Handling (RMS)900 Watts
Power Handling (MAX)1800 Watts
Frequency Response20 to 500Hz
Sensitivity93dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)18.8Hz
DC Resistance (Re)3.2Ω
Voice Coil Inductance (Le)2.24mH
Mechanical Q (Qms)4.05
Electromagnetic Q (Qes)0.35
Total Q (Qts)0.32
Compliance Equivalent Volume (Vas)9.61ft³
Mechanical Compliance of Suspension (Cms)0.14mm/N
BL Product (BL)23.4T·m
Diaphragm Mass Inc. Airload (Mms)499g
Maximum Linear Excursion (Xmax)12.75mm
Surface Area of Cone (Sd)1164cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter18.17"
Baffle Cutout Diameter16.69"
Depth8.94"
Sealed Volume2.9ft³
Sealed F347Hz
Vented Volume3.6ft³
Vented F329Hz
