  • Dayton Audio RSS460-PR 18" Reference Series Aluminum Cone Passive Radiator
Dayton Audio
Part #295-506
Dayton Audio
Part #295-506
Model: RSS460-PR
Dayton Audio's RSS460-PR 18" passive radiator is the ideal choice for tuning small enclosures lower than possible with a conventional port. With a thick aluminum cone, cast frame, rubber surround, and incredible excursion capabilities (68 mm peak to peak) this radiator is perfect for today's high excursion subwoofers.
  • SMS™ (Sandwich Mass System) permits greater linearity by minimizing angular torque
  • Durable yet compliant suspension provides substantial linear travel and mechanical stability
  • Rigid cast aluminum frame with thick black anodized aluminum cone
  • Threaded rod with lock nut for easy adjustment of tuning frequency
  • Includes eight 75 gram weighted disks for simple tuning adjustment
  • Cosmetically identical to the popular Reference Series subwoofer lines
Your Price: $199.98
MSRP: $239.99
Save $40.01 (17%)
Quantity:Qty: 1-3 $199.98/ea
Quantity:Qty: 4+$179.98/ea
We are proud to offer our customers the complete line of Dayton Audio Reference Series passive radiators. These high quality, well-engineered passive radiators are carefully constructed using the same rigid anodized aluminum cone and cast frame as Dayton Audio's world renowned Reference Series subwoofers, making them visually identical and a perfect match to the very popular line of drivers.
Mass Appeal
Each passive radiator employs the unique SMS™ (Sandwiched Mass Structure) design which keeps the majority of the mass centered between the surround and spider providing greater linearity by minimizing angular torque. These passives are also tunable using the included weights with the bolt-on mass adjustment assembly, making them easily integrated into virtually any subwoofer design.
Cast aluminum frame holds everything together
In order to support its extreme excursion, the RSS265-PR uses a rugged cast aluminum frame. The minimalistic design of the frame both eliminates unwanted flex and provides ample room for the rear of the cone. Plenty of room behind the spider makes sure that you can push the limits of excursion without bottoming out.
Packaged Contents
  • (1) Passive Radiator
  • (8) 75 gram disk weights
  • (1) Nylon locking nut (for final assembly)
Tip: As a general rule, the passive radiator(s) should have at least double the displacement of air (Vd) as the active woofer(s)/subwoofer(s) in the system. To calculate Vd=Xmax ∗ Sd
We've Got Your Back
Learn More
Shop All Reference Aluminum Passive Radiators
Capable of exceptional performance in everything from small subwoofers to 2-way designs, this series is incredibly versatile for whatever project you can come up with.
RSS210-PR
Nominal Diameter: 8"
Passive Radiator
Shop Now
RSS265-PR
Nominal Diameter: 10"
Passive Radiator
Shop Now
RSS315-PR
Nominal Diameter: 12"
Passive Radiator
    Shop Now
    RSS390-PR
    Nominal Diameter: 15"
    Passive Radiator
    Shop Now
    "I have a 24 x 24 living room with 18 foot ceiling this sub with 2 passive radiators slams drops low and loud I made my box with 2 layers of mdf it’s 7.5 cf and running a 1000 watt Dayton amp took a week to break in but wow it really compresses the air in here"
    - Eric E.
    ModelRSS460-PR
    Part Number295-506
    UPC848791002748
    Weight11
    Nominal Diameter18"
    Resonant Frequency (Fs)14.7Hz
    Mechanical Q (Qms)5.03
    Compliance Equivalent Volume (Vas)15.86ft³
    Mechanical Compliance of Suspension (Cms)0.23mm/N
    Diaphragm Mass Inc. Airload (Mms)500g
    Maximum Linear Excursion (Xmax)34mm
    Surface Area of Cone (Sd)1164cm²
    Cone MaterialAluminum
    Overall Outside Diameter18.17"
    Baffle Cutout Diameter16.69"
    Depth6.18"
    MONSTER DEAL
    OF THE WEEK
    $34.98 EACH
    SAVE 22%
    Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
