CLEARANCE Dayton Audio RSS390HE-22 15" Reference Series High Excursion Subwoofer 2+2 ohm
- Designed for maximum excursion and extended low frequency response
- Copper ring and thick aluminum sleeve minimize inductance to deliver ultra-low distortion
- Large 3” diameter voice coil is wound on a spiral cut aluminum former allowing high power handling
- Thick aluminum cone and dustcap improves heat dissipation to keep power compression under control
- Optimized venting for maximum airflow across the voice coil with extremely quiet operation
- Dual spiders and high roll surround reduce rocking modes during high displacement
- Dual 2 ohm voice coils give you the ability to get maximum power out of most amplifiers
We'll send you an email when Dayton Audio RSS390HE-22 15" Reference Series High Excursion Subwoofer 2+2 ohm is back in stock or available for preorder.
