  • Dayton Audio RS270-4 10" Reference Woofer 4 Ohm
Dayton Audio
Part #295-382
Dayton Audio
Part #295-382
Model: RS270-4
Dayton Audio Reference Series RS270-4 10" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
  • One of the lowest distortion, highest resolution driver series available
  • Compliant suspension and rigid black anodized aluminum cone for strong bass performance
  • Heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug
  • 89.2 dB sensitivity and 6 mm of excursion
Your Price: $98.99
MSRP: $142.99
Save $44.00 (31%)
Only 4 In Stock
The Dayton Audio Reference Series was conceived with one goal in mind—low distortion. Each speaker was carefully designed and optimized to offer the highest performance with the lowest distortion levels. At the same time, by focusing on features that contribute to sound quality and eliminating unnecessary frills, the drivers offer value unparalleled in the industry. Dayton Audio Reference Series RS270-4 10" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
ModelRS270-4
Part Number295-382
UPC848791002700
Weight8.45
Nominal Diameter10"
Bolt Circle Diameter10.16
Power Handling (RMS)100 Watts
Power Handling (MAX)200 Watts
Frequency Response21 to 2,000Hz
Sensitivity89.2dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)20.9Hz
DC Resistance (Re)3.9Ω
Voice Coil Inductance (Le)0.57mH
Mechanical Q (Qms)1.33
Electromagnetic Q (Qes)0.35
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)3.5ft³
Mechanical Compliance of Suspension (Cms)0.59mm/N
BL Product (BL)12.1T·m
Diaphragm Mass Inc. Airload (Mms)98.6g
Surface Area of Cone (Sd)346.4cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter10.71"
Baffle Cutout Diameter9.29"
Depth4.45"
# Mounting Holes6
Sealed Volume0.6ft³
Sealed F371Hz
Vented Volume1.25ft³
Vented F333Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
