Dayton Audio OP-4 Outrigger Speaker Spike Set with ABS Base 4 Pcs
Dayton Audio
Part #240-769
Dayton Audio
Part #240-769
Model: OP-4
Add a professional detail to your DIY speakers with Dayton Audio's OP-4 ABS outrigger set. The OP-4 outriggers attach directly to the bottom of a speaker enclosure and gracefully wrap up the side resulting in a clean look while widening the footprint to make tall speakers more stable. With optional spikes or foam pads, this outrigger set is suitable for use on any flooring surface.
- Create a stable base for your speakers using the included foam pads or spikes
- Adds a sleek and professional look to your DIY speaker projects
- Each outrigger can support 100 lbs., ideal for use with heavy tower speakers
- Edge mount design makes installation easy
