  • Dayton Audio ND140-8 5-1/4" Aluminum Cone Midbass Neo Driver 8 Ohm
Dayton Audio
Part #290-218
Dayton Audio
Part #290-218
Model: ND140-8
Dayton Audio's ND140-8's compact aluminum cone demonstrates the latest advances in high-excursion design processes. Its compact size and high output make it perfect for your next point-source or line array speaker project. When teamed up with the matching ND series passive radiators this driver can produce incredible full sound from compact enclosures.
  • Extended-range 54 Hz to 8 kHz performance
  • Rubber-edged aluminum alloy cone
  • Large excursion capability—4 mm Xmax, 20 mm peak
  • Self-shielded Neo-Balanced motor structure
  • 1" 4-layer underhung voice coil with polyimide former
  • 40 watts RMS power handling
Your Price: $29.98
MSRP: $44.99
Save $15.01 (33%)
Quantity:Qty: 1-3 $29.98/ea
Quantity:Qty: 4+$27.98/ea
Advertised price subject to change due to tariff uncertainty
Alert Me When Available
Dayton Audio's ND140-8 midbass driver features an efficient, low-distortion Neo-Balanced motor that is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source applications, or combined in multiples and line arrays.
ModelND140-8
Part Number290-218
UPC844632081491
Weight0.95
Nominal Diameter5-1/4"
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Frequency Response54 to 8,000Hz
Sensitivity84.5dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)56.5Hz
DC Resistance (Re)7.8Ω
Voice Coil Inductance (Le)1.44mH
Mechanical Q (Qms)5.01
Electromagnetic Q (Qes)0.79
Total Q (Qts)0.68
Compliance Equivalent Volume (Vas)0.27ft³
Mechanical Compliance of Suspension (Cms)0.76mm/N
BL Product (BL)6.05T·m
Diaphragm Mass Inc. Airload (Mms)10.4g
Surface Area of Cone (Sd)86.6cm²
Cone MaterialAluminum
Magnet MaterialNeodymium
Overall Outside Diameter5.43"
Baffle Cutout Diameter4.72"
Depth2.78"
Sealed Volume0.45ft³
Sealed F370Hz
Vented Volume0.75ft³
Vented F336Hz
