  • Dayton Audio MKBoom Portable Bluetooth Speaker Kit
Dayton Audio
Part #300-7166
Dayton Audio
Part #300-7166
Utilizing the same drivers as the popular Dayton Audio MK Series, the MKBoom Bluetooth Speaker Kit is an incredibly versatile, great sounding DIY speaker. The easily assembled kit includes the drivers, the KAB amp board with the necessary accessories, port tubes, crossover boards, and the knock-down cabinets. Add a handle for a portable design making the MKBoom the perfect grab-n-go speaker for everyday use.
  • Four driver design provides the same critically acclaimed audio quality as the Dayton Audio MK series of speakers
  • Battery powered Bluetooth amp with aptX HD make the MKBoom great for not only home audio but portable uses such as picnics, parks, and tailgating
  • Wide speaker dispersion range provides excellent sound coverage without compromising audio fidelity
  • Onboard panel controls allow you to easily connect to Bluetooth, power, and an Aux input
  • Easy to assemble with step-by-step instructions makes assembly simple
  • Includes everything needed to build the kit: cabinet, drivers, crossovers, amp, battery board, batteries, and 15 VDC 4A power supply
Your Price: $149.98
MSRP: $271.99
Save $122.01 (45%)
Portability and functionality meet hi-fi audio in the Dayton Audio MKBoom Bluetooth Speaker Kit. With the same great sound as the Dayton Audio MK series, the kit adds a level of versatility. Powered by a 2 x 50 watt amp, the kit delivers surprising power while remaining efficient enough to run on battery power. With the lack of a power cable needed, the MKBoom is the perfect grab-n-go speaker for patios, tailgates, parties, and parks. Easy to assemble, the MKBoom is a great introduction into speaker building.
Features:
  • Quad-driver design provides the same critically acclaimed audio quality as the Dayton Audio MK series of speakers
  • Battery powered Bluetooth amp with aptX HD makes the MKBoom great for not only home audio but portable uses such as picnics, parks, and tailgating
  • Includes everything needed to build the kit: cabinet, drivers, crossovers, amp, battery board, batteries and a 15VDC 4A Power supply
Customer Comments:
"My first build and had a ton of fun doing it." -David R. ⋆⋆⋆⋆⋆
"I would say this sounds as good or better than the Sony bluetooth speaker!" -T.R ⋆⋆⋆⋆⋆
"Built this with my sixth graders. it was a lot of fun..." - Micah M. ⋆⋆⋆⋆⋆
"Plenty loud to fill a good sized room. Buy it now. You'll love it." -Aaron H. ⋆⋆⋆⋆⋆
Meet the Designer:
Matt Phillips has been a tinkerer since a young kid. Matt discovered his passion for speaker building in high school, now he builds as much as possible to learn more and to help others gain knowledge.
Customer Projects:
Kit Components:
Part #QTY.Description
325-5051Dayton Audio KAB-250v4 2 x 50W Class D Audio Amplifier Board with Bluetooth 5.0
325-113
1Dayton Audio KAB-BE 18650 Battery Extension Board for Bluetooth Amplifier Boards
325-1161Dayton Audio KAB-PMV3 Panel Mount for KAB-v3 Boards with Function, LED, and Install Kit
142-103118650 2600mAh Li-Ion Flat Top Battery 3-pack
320-32911PC Board M3 Standoff Kit with 4 pcs 16mm Stud/ 4pcs 10mm Stud/ 4pcs Phillips Screw
295-4152Dayton Audio TCP1115-4 4" Treated Paper Cone Midbass Woofer 4 Ohm
275-0202Dayton Audio TD20F-4 3/4" Soft Dome Neodymium Tweeter 4 Ohm
081-4351#6 x 3/4" Deep Thread Pan Head Screws Black 16 Pcs.
120-057115V 4A DC Power Supply AC Adapter with 2.1 x 5.5mm Center Positive (+) Plug
Other1Cabinet, 2 x Crossovers and 2x Port Tubes for MKBoom Speaker Kit
Assembly Instructions:
Easy to follow step-by-step instructions walk you through the painless assembly process. In a matter of hours, you can assemble the kit which makes the MKBoom a great introduction into the speaker building world. The kit includes all the components needed to build an amazing sounding, portable speaker. Some standard tools are required to assemble the enclosure.
  • Power: 2 x 50 watts
  • Tweeter: 2 x Dayton Audio TD20F-4 3/4" Soft Dome Neodymium
  • Woofer: 2 x Dayton Audio TCP115-4 4" Treated Paper Cone Woofer
  • Frequency response: 50 - 20,000Hz
  • Battery Life: 8-10 hours at moderate volume
  • Recommended Power Supply: 15VDC 4A, 2.1x5.5mm Center positive (included)
  • Bluetooth Version: Bluetooth 5.0 with AptX HD
  • Dimensions: 17.75" W x 5.5" H x 7.5" D
ModelMKBoom
Part Number300-7166
UPC848864058245
Weight14.16
Cabinet Dimensions (HxWxD)17.75" W x 5.5" H x 7.5" D
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2-way
Speaker TypePortable Bluetooth
Woofer Diameter4"
