  • Dayton Audio MKBoom Portable Bluetooth Speaker Kit without Batteries
Dayton Audio
Part #300-7167
Dayton Audio
Part #300-7167
Utilizing the same drivers as the popular Dayton Audio MK Series, the MKBoom Bluetooth Speaker Kit is an incredibly versatile, great sounding DIY speaker. The easily assembled kit includes the drivers, the KAB amp board with the necessary accessories, port tubes, crossover boards, and the knock-down cabinets. Add a handle for a portable design making the MKBoom the perfect grab-n-go speaker for everyday use. Batteries are not included with this version of the MKBoom.
  • Four driver design provides the same critically acclaimed audio quality as the Dayton MK series of speakers
  • Battery powered Bluetooth amp with aptX HD make the MKBoom great for not only home audio but portable uses such as picnics, parks, and tailgating
  • Wide speaker dispersion range provides excellent sound coverage without compromising audio fidelity
  • Onboard panel controls allow you to easily connect to Bluetooth, power, and an Aux input
  • Easy to assemble with step-by-step instructions makes assembly simple
  • Includes everything needed to build the kit: cabinet, drivers, crossovers, amp, battery board, and 15 VDC 4A power supply (batteries not included with this version of the MKBoom)
Your Price: $144.98
MSRP: $261.99
Save $117.01 (45%)
Portability and functionality meet hi-fi audio in the Dayton Audio MKBoom Bluetooth Speaker Kit. With the same great sound as the Dayton Audio MK series, the kit adds a level of versatility. Powered by a 2 x 50 watt amp, the kit delivers surprising power while remaining efficient enough to run on battery power (this version of the MKBoom kit requires 3 x 18650 batteries). With the lack of a power cable needed, the MKBoom is the perfect grab-n-go speaker for patios, tailgates, parties, and parks. Easy to assemble, the MKBoom is a great introduction into speaker building.
Features:
  • The use of the efficient, yet powerful Dayton Audio KAB-250v4 2 x 50W Class D Audio Amplifier Bluetooth 5.0 makes the MKBoom extremely portable without sacrificing features and functionality.
  • With an efficient 2 x 50 watts of power, the amplifier delivers high-quality audio without a large power draw.
  • Since power consumption is low, the amp board can be powered by 18650 Li-Ion batteries using the KAB-BE battery extension board (batteries not included with this version of the kit).
  • Integrated Bluetooth 5.0 with aptX HD provides modern streaming convenience to the kit.
Customer Comments:
"Great project could be built in couple evenings I added leather handle, rubber feet, and got some high rated batteries from another source. Duratex coating is easy. Very happy with results!!" Stephen B ⋆⋆⋆⋆⋆
"First speaker build ever. Was a lot of fun, easy to put together, and they sound incredible." Philip H  ⋆⋆⋆⋆⋆
Meet the Designer:
Matt Phillips
Customer Projects:
Kit Components:
Part #QTY.Description
-1Cabinet, Crossover and Port Tube for MK Boom Portable BT Speaker Kit
325-113
1Dayton Audio KAB-BE 18650 Battery Extension Board for Bluetooth Amplifier Boards
325-1160.5Dayton Audio KAB-PMV3 Panel Mount for KAB-v3 Boards with Function, LED, and Install Kit
320-32912PC Board M3 Standoff Kit with 4 pcs 16mm and 4 pcs 10mm Stud 4 pcs Phillips Screws
295-4152Dayton Audio TCP115-4 4" Treated Paper Cone Midbass Woofer 4 Ohm
275-020.12Dayton Audio TD20F-4 3/4" Soft Dome Neodymium Tweeter 4 Ohm
120-057115 VDC 4A AC Adapter Power Supply with 2.1 x 5.5mm Plug Center Positive (+)
325-5051Dayton Audio KAB-250v4 2 x 50W Class D Audio Amplifier Board with Bluetooth 5.0
081-423125-Pack #6 x 3/4" Pan Head Deep Thread Black Screws
Fun and Simple Step-by-Step Assembly
Easy to follow step-by-step instructions walk you through the painless assembly process. In a matter of hours, you can assemble the kit which makes the MKBoom a great introduction into the speaker building world. The kit includes all the components needed to build an amazing sounding, portable speaker. Some standard tools are required to assemble the enclosure.
 Note: Batteries not included. This version of the MKBoom requires 3 x 18650 Li-Ion batteries for proper operation. To purchase the MKBoom kit with batteries included, see part number 300-7166.
 NOTE: Handle and feet are not included in the kit.
  • Power: 2 X 50 Watts
  • Tweeter: 2 X Dayton Audio TD20F-4 3/4" Soft Dome Neodymium
  • Woofer: 2 x Dayton Audio TCP115-4 4" Treated Paper Cone
  • Frequency response: 50 - 20,000 Hz
  • Battery life: 8-10 hours at moderate volume (with 3 x 2,600 mAh 18650 batteries)
  • Impedance: 8 Ohm
  • Recommended Power Supply: 15 VDC 4A, 2.1 x 5.5 mm center positive (included)
  • Bluetooth Version: Bluetooth 5.0 with aptX HD
  • Dimensions: 17.75" W x 5.5" H x 7.5" D
ModelMKBoom-NB
Part Number300-7167
UPC848864065236
Weight14.16
Cabinet Dimensions (HxWxD)17.75" W x 5.5" H x 7.5" D
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2-way
Speaker TypePortable Bluetooth
Woofer Diameter4"
