  • Dayton Audio MK442T 4" 2-Way Transmission Line Tower Speaker Pair
CLEARANCE Dayton Audio MK442T 4" 2-Way Transmission Line Tower Speaker Pair
Dayton Audio
Part #300-658
Dayton Audio
Part #300-658
Model: MK442T
  • Transmission line enclosure allows for high fidelity low frequency response
  • Pair with MK402 bookshelf and MK442 center channel speakers for a timbre matched home theater system
  • Impressive dispersion of this speaker allows it to be used in many configurations without deteriorated sound quality
  • Attractive textured, black vinyl finish that stands out
  • 4 ohm impedance is compatible with most receivers and amplifiers
Dayton Audio MK442T Tower Speakers
The MK Series of home speakers from Dayton Audio are the best way to add rich sound with elegance and sophistication. Built to last, the MK series makes it easy to listen to for hours and hours with it non fatiguing sound. Enjoying audio has never been this easy.
The Dayton Audio MK442Ts continue the motif of elegance and sophistication. All while sticking to the budget friendly sensibility that makes Dayton Audio a true value. This attractive 2-way speaker featuring dual 4" woofers and a 3/4" tweeter all packed into precision engineered transmission line enclosures will make many rethink their concept of what a budget speaker system is capable of. Great for music reproduction or even creating a complete timbre matched home theater setup; just add a pair of MK402 bookshelf speakers, an MK442 center channel and a powered subwoofer like our SUB-1500.
Majestic Design
The MK442Ts feature an attractive textured, black vinyl finish that stands out at first glance. The cabinet offers a unique geometric design that offers aesthetics not commonly found in this price range. The grill is removable and made with a high-quality black cloth that discretely obscures the most appealing features of this design, the drivers.
The MK442T tower speakers take advantage of quarter wave enclosure tuning to accomplish bass extension unheard of in this price range and form factor. With clean extended bass, full rich midrange, and smooth articulate high frequency response, the MK442Ts create a soundstage that is sure to impress.
Keynote Performance
The MK442Ts are engineered to disappear and deliver a transparent lifelike performance. Each speaker has an incredible wide listening field to provide excellent detail from any position. The unique faceted baffle on the front of each speaker does more than look beautiful, but actually help compensate for excessive treble, providing a smooth and non-fatiguing experience.
Superior Sound Through Engineering
The MK442Ts utilize a quarter wave transmission line enclosure. This proven loudspeaker technology makes it possible to produce deep articulate bass with smaller drivers and lower profile enclosures. Compared to a traditional bass reflex cabinet a transmission line is able to produce lower bass without the worry of port resonance and turbulence. This means better bass, lower distortion and a smaller footprint.
Elegant Silk Dome Tweeter
The 3/4" tweeter offers superior off axis response which helps create a large, engaging soundstage. The low mass diaphragm offers an exceptionally flat frequency response. This along with the low distortion neodymium motor system ensures that high frequency content is reproduced as transparently as possible.
Felt, And Heard
The MK442Ts use the same 4" treated paper cone woofer as the critically acclaimed MK402 and award winning MK442 speakers. This 4" treated paper cone woofer boasts a 1" diameter 4-layer voice coil offering improved power handling and low frequency response. An extended pole piece creates symmetrical magnetic field for lower distortion. The large rubber surround allows for high excursion, all this equates to focused and accurate mid frequencies and impressive low end bass extension.
More Than Just A Crossover
The crossover featured in the MK442T utilizes a 3 kHz, 2nd order low pass and a 3rd order high pass section. The board is then affixed to the rear of the recessed terminal cup which features a pair of 5-way gold-plated binding posts. The crossover was designed and optimized to deliver the smoothest, flattest frequency response possible.
Here's What Our Customers Are Saying
Modern Marvel
"These amazing speakers were a perfect solution for a music only system I have in my bedroom. The system is required to have excellent clarity, imaging, and full range at all volume levels, especially lower volume. The Dayton MK442T delivers all this and great true sounding bass in the spirit of the great transmission line speakers like IMF and PMC. Simply a marvel at this price. Get a pair now."
John L.
Don't Take Our Word For It
Actually, It's Not Just Our Customers...
Dayton Audio is proud to have the MK442T honored as Audioholic's 2019 Best Budget Speaker of the Year
Read The Full Review
  • Design: 2-way dual 4" transmission line tower speaker
  • Woofer: Dual 4" treated paper cone
  • Tweeter: 3/4" soft dome
  • Finish: Black vinyl
  • Power handling: 80 watts RMS/160 watts max
  • Impedance: 4 ohms
  • Frequency response: 40 to 20,000 Hz
  • Sensitivity: 87 dB 1W/1m
  • Crossover: 2-Way 3.3kHz crossover with 2nd order slopes
  • Terminals: 5-way gold plated binding posts
  • Port tuning: 50 Hz
  • Dimensions: 38.1" H x 5.7" W x 9.6" D
We Got Your Back
Explore the Entire MK Series
This full selection of MK speakers includes bookshelf, floorstanding, a center channel and a subwoofer, making it easier than ever to get the most detail out of a two-channel or surround sound system.
MK402X
4" 2-Way Bookshelf Speakers
Shop Now
MK402BTX
Bluetooth 4" 2-Way Bookshelf Speakers
Shop Now
MK602X
6" 2-Way Bookshelf Speakers
Shop Now
MK442T
L4" Dual 2-Way Tower Speakers
Shop Now
MK442
4" Dual 2-Way Center Channel Speaker
Shop Now
MKSX4
Passive quad driver subwoofer
Shop Now
Featured Bundles
Due to their uniform look and sound MK Series Speakers can be easily combined to build a wide variety of systems. Add a subwoofer to your stereo pair for a extremely powerful low end, or completely upgrade your home theater experience with in immersive surround sound experience.
MK442 Cinema 5.1
When Combined, MK speakers create a wonderful cinematic experience. Every speaker in this system is designed in conjunction with one another to match both aesthetically and sonically.
Shop Now
MK602 Tube Stereo
The Dayton Audio HTA100BT is a perfect companion to the MK602X bookshelf speakers, and together with MK602X speakers you'll enjoy your favorite music for hours on end. Vintage tubes bring classic warmth and character to a modern stereo system with wireless Bluetooth streaming.
Shop Now
Build Your Own Portable MK Speaker
Utilizing the same drivers as the popular Dayton Audio MK Series, the MKBoom Bluetooth Speaker Kit is an incredibly versatile, great sounding DIY speaker. The easily assembled kit includes the drivers, the KAB amp board with the necessary accessories, port tubes, crossover boards, and the knock-down cabinets. Add a handle for a portable design making the MKBoom the perfect grab-n-go speaker for everyday use.
Need Inspiration? See What Others Have Built
Build by Michael C.
Build by Nick W.
ModelMK442T
Part Number300-658
UPC848864053714
Unit of MeasurePairs
Weight52
ColorBlack
Configuration2-way
Input Rating4 ohm
Woofer Diameter4"
