  • Dayton Audio KABD-PMV4 Panel Mount with Function Kit and Potentiometers
NEW Dayton Audio KABD-PMV4 Panel Mount with Function Kit and Potentiometers
Dayton Audio
Part #325-118
Dayton Audio
Part #325-118
Model: KABD-PMV4
Are you looking to give your Dayton Audio KABD sound projects a professional finish? Look no further than the KABD-PMV4 Panel Mount Kit! This kit is specifically designed to provide all the necessary components and accessories to make your KABD amp board ready for speakers and power, while giving it a sleek and polished look.
  • Silk screen labels identify each function for ease of use and a professional finish
  • Predrilled holes save time mounting each component
  • Standoffs attach the KAD board to the KABD panel for one piece installation
  • Gasket tape and wood screws for a secure fit
  • Included components plug directly into the board without soldering
  • Volume plus three more controllers to add more instant frequency adjustments
  • Includes scratch off labels for the remaining three controllers for customization
NEW $19.98
MSRP: $29.99
Save $10.01 (33%)
Quantity:Qty: 1-9 $19.98/ea
Quantity:Qty: 10+$17.98/ea
Included in the kit is everything you need for a seamless installation. You will find a DC coax 2.1 x 5.5 mm power jack, a rocker switch, standoffs, four potentiometers, a pairing switch, gasket tape, and mounting screws. The best part is that these components plug directly into the board, eliminating the need for any soldering. Installation has never been easier!
To make the process even more convenient, the panel comes with predrilled holes and silk screen white labels, allowing you to identify the location and function of each component with ease. No more guesswork or confusion!
Furthermore, the kit includes a scratch on transfer sheet for three blank control options, giving you the freedom to customize your project according to your preferences. Additionally, black plastic buttons are provided to cover any unused holes, ensuring a clean and professional appearance.
The standoffs included in the kit serve as a sturdy support system, holding the panel and the KABD board firmly together for one-piece mounting. This ensures that your project stays securely in place, even during heavy use.
To complete the installation, gasket tape and screws are included to securely mount the panel to your project. This ensures that the panel stays firmly in place, while also providing a neat and finished look.
With the KABD-PMV4 Panel Mount Kit, you can take your Dayton Audio KABD sound projects to the next level. Give them a professional finish and enjoy the satisfaction of a job well done. So why wait? Get your kit today and transform your project into something truly remarkable!
Included Components:
PartsDescriptionSpecificationQty
PanelBlack metal4.75" H x 3.76" W x 0.09" D (120 x 95 x 2.3 mm) with screw hole spacing 4.37" and 3.39" (111 x 86 mm) apart for mounting1
ScrewsBlack for front of standoffM3 x 6 mm4
ScrewsSilver for rear of standoffM3 x 6 mm4
StandoffsSilverM3 x 60 mm4
ScrewsBlack wood screws for mountingM3 x 16 mm8
LEDsRed and blue with metal socket and cables5 mm with 20" (500 mm) leads2
PotentiometerVolume control, knob, and cable10K ohm with 20" (500 mm) leads4
Push button switchPush button and cable for Bluetooth pairingSPST momentary N.O. with 20" (500 mm) leads1
Stereo phone JackAux input and cable3-conductor 3.5 mm with 20" (500 mm) leads1
DC coax jackDC input and cable2.1 x 5.5 mm with 20" (500 mm) leads1
Rocker SwitchOn-off switch and cableSPST with 20" (500 mm) leads1
Gasket tapeGasket tape for underneath the outer diameter of the panel4.61" L x 0.39" W (117 x 10 mm)2
Gasket tapeGasket tape for underneath the outer diameter of the panel3.47" L x 0.39" W (88 x 10 mm)2
WrenchWrench for LED mounts10 mm1
Allen wrenchDriver for screws2.5 x 55 x 18 mm1
ModelKABD-PMV4
Part Number325-118
UPC848791010187
Weight0.45
Board TypePanels & Mounting Acc.-Wiring Harness
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
