  • Dayton Audio IO8XTW 8" Indoor/Outdoor 2-Way Speaker w/ Bass Radiator White
Dayton Audio
Part #310-036
Dayton Audio
Part #310-036
The Dayton Audio IO8XTW 8" IP66 Indoor/Outdoor Speaker brings unprecedented audio fidelity outdoors. With both 70V/100V taps and 8-ohm bypass, the weather-resistant IO8XTW speaker can be used for both commercial and residential installs. Dayton Audio has once again delivered extreme versatility, outstanding value, and exceptionally great sonic performance at an affordable price.
  • Passive radiator produces extended low-end response for deep, tight bass uncharacteristic of outdoor speakers
  • Both 8 ohm and 70V/100V taps that are compatible with both consumer and commercial amplifiers
  • High excursion 8" polypropylene woofer and 1" silk dome tweeter provide a smooth, natural listening experience
  • Sealed IP66 ABS enclosure protects the speaker from water damage making the speaker great for outdoor use
Your Price: $194.98
MSRP: $289.99
Save $95.01 (33%)
Dayton Audio IO8XTW 8" Indoor/Outdoor 2-Way Speaker with Radiator White
Utilizing a passive radiator, the Dayton Audio IO8XTW Indoor/Outdoor Speakers delivers a surprising amount of low-end while remaining suitable for outdoor use. The IO8XTW is suitable for use in both commercial and consumer applications with 70V/100V taps as well as an 8-ohm bypass. The flexible nature of the speakers make them perfect for patios, pools, gardens, offices, bars, and hotels.
Key Specs:
  • Design: 8" 2-Way Indoor Outdoor Speaker
  • Woofer: 8" Polypropylene Cone
  • Tweeter: 1" Soft Dome
  • Power Handling (RMS): 80 Watts @ 8 Ohms
  • Power Handling (MAX): 160 Watts @ 8 Ohms
  • Frequency Response: 38-20,000 Hz
We Got Your Back
Incredible Bass Response
The IO8XTW challenges the notion that outdoor speakers lack in low-end response. Without sacrificing durability, the IO8XTW is able to produce extended bass by using a passive radiator. The passive radiator design allows the speaker to provide a surprisingly deep, tight bass response while keeping the enclosure small. The superb bass and natural, smooth high-end create an enjoyable listening experience no matter where installed, indoors and out.
Consumer & Commercial Applications
Flexibility makes the IO8XTW a perfect go-to speaker in any type of install. With 70V/100V transformer taps, the speaker can be used in commercial installations such as background music and paging systems in bars, hotels, conference rooms, and offices. In addition, the IO8XTW includes an 8-ohm bypass option for use with consumer amps for residential applications such as pools, patios, gardens, and porches. The IO8XTW is a great option for virtually any installation, residential or commercial.
70V/100V Transformer with 8 Ohm Bypass
For Use Indoors & Out
Flaunting an IP66 ABS enclosure, the IO8XTW is perfect for outdoor use. The water-resistant build allows for the speaker to be used in outdoor applications, even in unfavorable environmental conditions. Rugged and durable build quality ensures a long life for years of enjoying great sounding audio.
Uses:
  • Larger outdoor gathering spaces
  • Pools and theme parks
  • Entertainment venues
  • Warehouses, shipping centers
Installer's Dream
Included brackets allow for the speaker to be mounted either vertically or horizontally with the ability to pivot making installation simple and quick. Since the speakers are easy to install and a breeze to position, the IO8XTW saves both installation time and money allowing for adherence even to the tightest budget..
Shop the Whole IOX Line
IO65XTB 6-1/2"
IO65XTW 6-1/2"
IO8XTB 8"
IO8XTW 8"
  • Size: 6-1/2"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: White
  • Sold As: Pairs
  • Size: 8"
  • Color: Black
  • Sold As: Single
  • Size: 8"
  • Color: White
  • Sold As: Single
Shop All Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8‑ohm bypass
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Available in 5‑1/4", 6‑1/2", and 8" versions in black and white
IOXT Line
  • Passive radiator produces extended low‑end response for deep, tight bass uncharacteristic of outdoor speakers
  • Sealed IP66 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6‑1/2" and 8" versions in black and white
Pendant Line
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8‑ohm bypass
  • Suitable for indoor and outdoor installation
  • Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
Outdoor Subs
Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
Shop Now
Impressive Sound
"Installed these in a small restaurant lounge. Impressive sounding with plenty of low end as well as crisp clear highs without any tuning yet."
- Ivan B
  • Design: 8" 2-Way Indoor Outdoor with Passive Radiator
  • Impedance: 8Ω / 70V
  • SPL: 87 dB 1W/1m
  • 70V Taps: 6.25W, 12.5W, 25W, 50W
  • Ingress Protection Rating: IP66
  • Dimensions: 14.875"H x 9.875"W x 9.375"D
  • Weight: 7.6 lbs. (each)
ModelIO8XTW
Part Number310-036
UPC848791007804
Weight13.8
ColorWhite
Configuration2-way
Input Rating8 ohm | 70 volt | 100 volt
Mounting StyleWall Mount
Woofer Diameter8"
Special FeaturesIndoor / Outdoor-Water Resistant
