Dayton Audio Mid-bass Audio Exciter IMS Mount 32mm 40W 4 Ohm EX32VBDS-4
- Dual suspension increases excursion for low-frequency reproduction
- Exclusive IMS™ Interchangeable mount allows you to A/B test different exciters
- Rare-earth neodymium motor and a proprietary two-layer voice coil
- Heavy-duty design with a 32mm voice coil for a high 40 watt RMS power handling
- Easily swap non-functional units out in the field
- 4-ohm impedance for use with small, Class D amplifiers
- Pre-applied 3M VHB™ adhesive for quick, durable installation
Only 9 In Stock
We'll send you an email when Dayton Audio Mid-bass Audio Exciter IMS Mount 32mm 40W 4 Ohm EX32VBDS-4 is back in stock or available for preorder.
