  • Dayton Audio IMS Mount Disc 5-Pack Audio Exciter EX2HMP-5
Dayton Audio
Part #295-999
Dayton Audio
Part #295-999
Model: EX2HMP-5
Take your product or project to the next level by turning it into a speaker! The EX2HMP is part of an exclusive IMS™ interchangeable mounting system from Dayton Audio, compatible with all IMS™ exciters from Dayton Audio!
  • Exclusive IMS™ interchangeable mounting system
  • Compatible with all IMS™ Dayton Audio's exciters
  • Screw-on 2-hole mount with Pre-applied 3M VHB™ adhesive for a quick, secure installation
Your Price: $9.98
MSRP: $12.99
Save $3.01 (23%)
Quantity:Qty: 1-3 $9.98/ea
Quantity:Qty: 4+$8.98/ea
120In Stock
Dayton Audio EX2HMP-5 IMS™ Exciter Interchangeable Mounting Disc 5-Pack
Having extra IMS™ mounting discs allow you to try any of the Dayton Audio IMS™ exciters in various locations to find the sound you are looking for.
Surface exciter technology provides a universal, cost-effective alternative to loudspeakers, allowing for sound reproduction virtually anywhere it is desired. Issues such as weather, space constraints, vandalism or visibility can be avoided or minimized with the use of a sound exciter. Dayton Audio IMS™ Interchangeable Mount exciters may be used in a host of DIY executions to easily add sound to an existing non-audio specific project or create a portable speaker system, the unique mounting system allows you to try out the assortment of exciters offered by Dayton Audio!
Want to learn more about exciters? See our Exciters & Tactile Transducers Introduction Paper!
The IMS™ Exclusive Interchangeable Mounting System
With Dayton Audio's IMS™ exclusive interchangeable mounting system, you can try out many different configurations, placements, and exciters to find the best combination for your project. Each exciter comes with a threaded mounting pad that can be permanently installed anywhere. Installation is easy, simply remove the pad from the exciter assembly, mount the pad to your project with 2 screws or with the 3M VHB™ Adhesive, and screw the exciter assembly back onto the pad! The non-destructive nature of the IMS™ interchangeable mount allows you to A/B different exciters or swap non-functional units out in the field without risking damage to your project or exciters.
We've Got Your Back
Learn More
See All Of Our Dayton Audio's IMS™ Interchangeable Mount Exciters
All of Dayton Audio's IMS™ interchangeable mount exciters take advantage of the same mount to provide an easily swappable configuration, pick up yours today from Dayton Audio!
EX25CT2-4
Nominal Diameter: 25mm
Impedance: 4 Ohms
Shop Now
EX25VT2-4
Impedance: 4 Ohms
Shop Now
EX25FHE2-4
Impedance: 4 Ohms
Shop Now
EX32EP2-4
Nominal Diameter: 32mm
Impedance: 4 Ohms
Shop Now
EX32U2-4
Impedance: 4 Ohm
Shop Now
EX30HESF2-4
Nominal Diameter: 30mm
Impedance: 4 Ohms
Shop Now
EX32Q2-4
Impedance: 4 Ohms
Shop Now
EX32Q2-8
Impedance: 4 Ohms
Shop Now
Show Off Your Builds
We would love to see what you can build. Show off your creativity and skills by uploading to our project gallery.
For inspiration, see what others have built below:
Submit your projects to receive a 6-month digital subscription to audioXpress magazine
Shimmer Tree by Dan Fox
Shimmer Tree is an impressive six metre high tree-like sound and light sculpture controlled by the wind. As the listener wanders underneath, the directional sound and changing resonances envelope the listener in an evolving and meditative sound bath that responds to the environment. It has 12 branches and 12 large cymbals suspended above head height. Each cymbal is fitted with a tactile transducer, transforming it into a metallic resonator speaker.
SoundPhoto by David F Giroux
I started with a vibrant 12×24″ metal print of fireworks over the Madison, Wis. city skyline — the “Shake the Lake” show over Lake Monona. This is my own photo, in a high-resolution professional print directly on a sheet of polished aluminum with1.5″ inset metal frame on the back. I installed a Dayton audio 15w/ch amp and 2 Dayton exciters behind the panel. Power switch, volume control, and aux audio input mounted discreetly on the side.
Bertha by Matty Hughes
My new 192 Watt DIY DML panel build (Bertha)! At 20in x 22in each 1/4″ thick plexiglass panel is running at 4 ohm’s @ 96 Watts, exciters wired in a series-parallel configuration for each panel and powered by a HiFi 100W x 2 (200W) Bluetooth 5 amp with a 24V 10a power supply. A total of 8 Dayton Audio DAEX25FHE-4 Framed High Efficiency 25mm Exciters each 24W 4 Ohm were used for this DML build.
Build Your Own Speakers
Make Science Fair projects come alive by adding exciters and a Bluetooth amplifier to your presentation boards. Add verbal explanations and sound effects to get the best grade in the class.
Don't stop with presentation boards. Attach these peel-and-stick exciters to any thin flat surface and bring multimedia sound to paintings, cardboard figures, mock boom boxes, doll houses, and other large models. Download a super hero theme song and turn your favorite freestanding cardboard hero into a Bluetooth speaker. Download the sound of waves to make an ocean painting come to life. Turn a doll house into a Bluetooth speaker and have the power switch built into the home theater room's miniature multimedia receiver. Add music and sound effects to enhance presentations by hiding the Bluetooth amp and exciters inside large scale models. As you can see the possibilities for this Science Fair Bluetooth amp exciter kit are limitless.
Speaker Kit Walk Throughs
How-To Collection
ModelEX2HMP-5
Part Number295-999
UPC848791008610
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
