  • Dayton Audio DMK-1 Delta Mass Scale and Weight Kit
NEW Dayton Audio DMK-1 Delta Mass Scale and Weight Kit
Dayton Audio
Part #390-802
Dayton Audio
Part #390-802
Model: DMK-1
Enhance your speaker design and testing workflow with the Dayton Audio DMK-1 Delta Mass Scale and Weight Kit, an indispensable tool for Dayton Audio DATS users. This kit includes a precision digital weight scale and 50 grams of museum putty, simplifying the process of obtaining Thiele/Small parameters and VAS values using the delta mass method (added mass). Ideal for DIY enthusiasts and speaker designers seeking accurate speaker parameters.
  • High-Precision Digital Scale: Enables accurate weighing of small masses critical for speaker analysis.
  • Museum Putty: Four strips of non-damaging, reusable putty for easy mass addition to speaker cones (50 grams total).
  • DATS V3 and DATS LA Compatibility: Optimizes the capabilities of the DATS measurement systems for precise Thiele/Small parameters.
  • Effortless Operation: Designed for ease of use, ensuring a smooth measurement process for DIY users and speaker designers.
  • Complete Measurement Solution: Everything needed for immediate, accurate speaker testing is included.
NEW $19.98
MSRP: $29.99
Save $10.01 (33%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$18.98/ea
Order in the next 2 hr 29 min to ship today. Details
Embrace the next level of speaker measurement accuracy with the Dayton Audio Delta Mass Kit. Designed as the perfect add-on for the DATS V3 and DATS LA systems, this kit provides DIY enthusiasts and speaker designers with the tools needed for precise, hassle-free measurement processes.
Precision at Your Fingertips
The included digital scale is ideal for the delta mass (added mass) method of measuring a loudspeaker driver's mechanical specifications (Vas, Mms, Cms, etc..). This precision tool ensures that the mass added to the speaker cone is measured accurately, facilitating both DATS measurement systems in calculating detailed Thiele/Small parameters.
Note: Scale weight capacity is 0.1g to 1000g.
Safe and Effective Mass Addition
With four strips of museum putty, the Delta Mass Kit allows users to safely add mass to the speaker cone without risking damage. This reusable putty is designed to stick to the cone firmly yet remove cleanly, ensuring that your speakers remain unharmed throughout the measurement process.
Note: 50 grams of museum putty is included.
Streamlined Measurement Process
Acknowledging the needs of DIY audio enthusiasts and professional speaker designers, the Delta Mass Kit has been crafted to offer a seamless integration with the DATS V3 and DATS LA systems. This kit empowers users to achieve professional-grade measurements in the comfort of their own workshops, pushing the boundaries of custom audio design. By simplifying the mass addition step, the Delta Mass Kit not only makes the measurement process more efficient but also significantly enhances the accuracy of the DATS readings. This results in a more reliable and user-friendly experience, enabling you to focus on designing and optimizing your audio projects.
ModelDMK-1
Part Number390-802
UPC848791009587
Weight0.7
