  • Dayton Audio DATS V3 Computer Based Speaker & Audio Component Test System
Dayton Audio
Part #390-807
Dayton Audio
Part #390-807
Model: DATS V3
Dayton Audio has taken the most complete and easy-to-use audio test system and improved it in almost every way when creating the DATS V3 Computer Based Audio Component Test System. With improvements to the accuracy, capability, and reliability of the DATS V2, the DATS V3 sets a new standard for quick and accurate audio component measurements.
  • Rugged aluminum housing with detachable test leads and built-in precision calibration resistor
  • Tighter tolerances on internal components for more precise measurements
  • Increased output capability means greater separation from the noise floor, resulting in more accurate measurements
  • DATS Linearity Test for comparing parameters and impedance plots at multiple drive levels
  • Optional under desk mounting brackets included to save desk space
  • Only 1" H x 2-1/2" W x 4-1/8" D for easy portability
Your Price: $129.98
MSRP: $189.99
Save $60.01 (32%)
Order in the next 3 hr 39 min to ship today. Details
The Perfect Companion for Audio Professionals
When designing the DATS V3 measurement device, Dayton Audio took everything customers love about the DATS V2 and improved upon the accuracy, capability, reliability, convenience, and flexibility.
Any engineer knows that valid and accurate data is crucial to great results. DATS (Dayton Audio Test System) V3 is the essential tool in any speaker designers or audio engineers toolbox, providing accurate, precise measurement data for any audio transducer or loudspeaker system. Save yourself time, money, and trial-and-error frustration by using DATS V3 to measure loudspeaker drivers, crossover networks, and complete audio systems!
DATS V3 is a unique, multipurpose test system that works with your PC and full-featured test software to measure the impedance response of a speaker driver and derive a complete set of Thiele/Small parameters that describe its operation. Its as easy as connecting a driver and starting the test! The DATS V3 measurement module provides the electrical stimulus to the driver, measures the drivers impedance on the fly, and then creates a high-resolution graph (30,000 data points!) with no additional hardware required.
Whats better about Version 3?
From the outside, the DATS V3 has a completely updated look and feel. The extruded aluminum housing makes DATS V3 durable enough to throw into a toolbox without worrying about damage. In addition, optional mounting brackets give you the option to mount the DATS V3 under a desk or test bench to save space. No more searching for a calibration resistor, it is now integrated into the case, just clip the test leads onto the pins on the front of the housing and run the calibration. Also, the test leads have been upgraded to removable insulated banana plug test leads, giving you the ability to use your favorite test leads and easily replace damaged test leads (test leads are included). Finally, we have added a USB-B jack rather than an integrated USB cable (USB A to B cable included). This allows the cable to be quickly swapped if there is any damage, or if a different length is preferred.
The improvements continue on to the inside of the DATS V3. The internals have been completely redesigned and improved to deliver better accuracy and more power. With increased output power, the DATS V3 allows you to take measurements at a higher level to minimize the chance that a high noise floor or vibration could affect measurement results. Dayton Audio has also upgraded many of the internal components with tighter tolerances to minimize the margin of error that is caused by a components value variance. Even the calibration resistor has been upgraded to 0.1% tolerance.
DATS V3 software is the true power of DATS. The included software not only measures impedance and parameters of speaker drivers with incredible accuracy, but the addition of the DATS Linearity Test gives you the ability to observe changes in parameters with differing drive levels. The Linearity Test automatically performs multiple sweeps of the driver at increasing (or decreasing) levels while saving each test result to memory making it easy to recall and compare the results. As always, the DATS V3 still has the capability to measure the true value of inductors, capacitors, and resistors, and it also works as a signal generator and scope to let you monitor small electrical signals (line-level only). Even more updates are planned to further set DATS V3 apart from the competition.
Features
  • Linearity test allows you to easily observe shifting parameters with different drive levels
  • Increased output capability for greater separation from the noise floor for more accurate measurements
  • Optional under desk mounting brackets to save desk space
  • Precise impedance response measurement for loudspeaker drivers and complete systems
  • Accurate measurement of loudspeaker electromechanical parameters (Fs, Qts, Vas, and many more)
  • Measurement of advanced Wright Model parameters (Kr, Xr, Ki, Xi) for precision simulations
  • Precise, high-resolution impedance response measurements with 30,000 data points (1 Hz to 20,000 Hz)
  • Save and compare up to 20 impedance graphs simultaneously within one test file
  • Integrated quality control feature set provides pass/fail parameter measurement
  • Sensitive rub and buzz detection functionality reveals hidden flaws in individual drivers
  • Software signal generator with selectable waveform, frequency, and amplitude
  • Generates sine, square, triangle, saw tooth, impulse, pink noise, and log sweeps
  • Oscilloscope software mode with dual traces, plus adjustable time and amplitude scales
  • Oscilloscope and generator modes are compatible with other audio interfaces
  • Quality test interface hardware assembled using precision SMT components and automation
  • High-quality alligator clip leads minimize contact resistance for improved consistency
  • Includes method for calculating Vas from specified Mmd
  • Faster-than-ever hardware startup time virtually eliminates warm-up/cool-down
Measurements
The DATS V3 software provides you with an array of tools that are great for all speaker designers
  • Measures T/S parameters
  • Linearity test
  • Precise impedance measurement
  • Efficient Pass/Fail workflow
  • Calculates VAS from Mmd
  • Resistor measurement
  • Signal generator with 10 different functions
  • Measures advanced Wright model parameters
  • Rub and buzz detection
  • Oscilloscope with dual traces
  • Capacitor measurement with ESR, dissipation factor, and Q
  • Inductor measurement with DC resistance
DATS V3 vs. DATS LA:
DATS V3DATS LA
Quick setup and easy to use
Integrated 100 watt amplifier
Small signal parameter measurement
Large signal parameter measurement
Adjustable small signal level
Adjustable large signal level
Motor symmetry measurement
Suspension symmetry measurement
Measure parameter vs. displacement
Calculates displacement per voltage
Measures capacitors, inductors, and resistors
Oscilloscope and signal generator
USB powered
Compact and readily portable
A solution like no other
DATS V3 is faster, more elegant, more versatile, and easier to use than any other speaker test & measurement device. Get ready for your designs to make a quantum leap, thanks to better data!
T/S Parameter Measurement
Quickly and accurately measure a drivers T/S parameters. Just attach the test leads directly to a driver's terminals and click "Measure Free-Air Parameters" and the impedance magnitude will be displayed on the graph along with the measured Re, Fs, Qts, Qes, Qms, and Le. Next add mass to the cone or mount the driver in a suitable test box and click "Measure V(as)" to derive the mechanical parameters such as Vas and Mms.
Enclosure Tuning Verification
Once your driver is mounted in an enclosure DATS V3 makes it easy to verify your system's overall tuning for vented enclosures or Q for sealed enclosures by using the "Measure Free Air Parameters" button. The system will run a quick sweep and plot the impedance magnitude making it easy to verify the actual tuning of your system.
Verify Crossover Wiring and Performance
Once your speaker system is complete, you can run an "Impedance Sweep" to plot the overall system impedance. A quick comparison of the measured impedance to your modeled impedance makes it easy to ensure that your crossover is wired correctly and performing as intended.
Oscilloscope and Signal Generator
A software oscilloscope allows you to visually observe the behavior of a circuit when presented with or without stimuli. Used in conjunction with the built-in signal generator, you'll be able to hunt down any strange phenomena, or confirm that your system is running properly.
Precision LCR Meter
Capacitor Measurements
As a capacitance meter DATS V3 is in a league of its own. In seconds, it will measure all of a capacitor's electrical characteristics including capacitance, equivalent series resistance, Q, and even loss angle. DATS V3 is capable of accurately measure capacitance from 0.002 uF to 10,000 uF.
Inductor Measurements
Measure both the inductance and DC resistance of a coil with just one click. The DATS V3 is accurate from 0.05 mH up to 100 mH.
Resistor Measurements
Naturally, DATS V3 is also perfect for measuring resistance. As a unique feature, it will also plot the impedance of a resistor allowing you to see just how non-inductive your resistors really are. Resistance measurements are accurate from 0.002 ohms up to 10,000 ohms.
Join Our Speaker Building Community
Learn more about DATS V3 from seasoned professionals
ModelDATS V3
Part Number390-807
UPC848791006470
Weight0.95
