  • Dayton Audio DTA-100ST 100W Desktop Stereo Amplifier with Bluetooth 5.0
Dayton Audio
Part #300-3807
Dayton Audio
Part #300-3807
Model: DTA-100ST
The DTA-100ST is a 100W stereo amplifier with Bluetooth 5.0 connectivity that is crafted with an all-metal construction and a brushed black aluminum faceplate. This compact tabletop amplifier is a blend of simplicity, elegance, and power.
  • 100 watts of clean, low distortion power, capable of filling your space with high-resolution audio
  • Bluetooth 5.0 for wireless streaming, and a pair of line level RCA inputs and outputs
  • Adjustable high-pass filter, ranging from 20Hz to 250Hz, applied to speaker outputs
  • Automatically turns off after 15 minutes of inactivity, a feature that can be disabled as needed
  • Minimum impedance of 4 ohms
  • Highly durable all-metal build with a standard 5-year warranty provided by Dayton Audio
Your Price: $134.98
MSRP: $194.99
Save $60.01 (31%)
Order in the next 2 hr 7 min to ship today. Details
Designed to work in perfect harmony with the Dayton Audio DTA-100LF, the DTA-100ST is ready to be the centerpiece of your audio setup or effortlessly blend into the background. With its oversized silver volume knob and two sleek silver buttons, this amplifier commands attention while maintaining a no-frills aesthetic.
Quality Audio Performance
At the heart of the DTA-100ST is 100 watts of clean, low distortion power. This amplifier will fill your space with high resolution audio, providing a flat frequency response from 20Hz to 20,000Hz. Whether you're streaming wirelessly through Bluetooth 5.0 or using the line level RCA inputs, the DTA-100ST ensures your audio is always crystal clear.
Compact and Versatile
Whether you're looking to power small speakers for your desktop or create a larger component system, the DTA-100ST is the perfect fit. Its dimensions of 7.5" wide, 6" deep, and 2" tall, with a weight of just 2.78lbs, makes it an ideal choice for those seeking high-quality audio without sacrificing space.
Convenient and User-Friendly
The DTA-100ST is all about convenience, one of the standout features of this amplifier is its adjustable high-pass filter. With a range of 20Hz to 250Hz, this filter can be applied to the speaker outputs and is designed to work in tandem with the DTA-100LF. For those seeking full range output, the filter can be easily disabled. Full-Range pre-amplified outputs on the back allow you to chain other equipment after the DTA-100ST for further processing or amplification. An additional auto-on functionality will automatically power the unit off after 15 minutes of inactivity, but this feature can be deactivated as needed.
Durability and Assurance
Despite its compact size, the DTA-100ST doesn't compromise on build quality. The all-metal construction provides an extra layer of durability, ensuring that your amplifier will stand the test of time. Plus, with a 5-year warranty provided by Dayton Audio, you can purchase with confidence.
Part of a Bigger Family
The DTA-100ST is more than just an amplifier—it's part of a larger family. Designed to integrate seamlessly with Dayton Audio's DTA line, including a Low Frequency Amplifier, the DTA-100ST can be the cornerstone of an impressive audio setup.
  • RMS Power Output: 55 WPC @4ohms 22WPC @8ohms
  • THD+N: <0.5% at rated output 4ohms (<0.25% at 8ohms)
  • Frequency Response: 25 - 20000Hz
  • Input Sensitivity: 0.95V
  • Minimum Speaker Impedance: 4Ohm
  • SNR: 101dB
  • Bluetooth: 5.0
  • Dimensions (WxHxD): 7.5 x 2 x 5.5 in.
  • Weight: 2.78lbs
ModelDTA-100ST
Part Number300-3807
UPC848791008757
Weight3.75
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range< 10 lbs.
Special FeaturesBluetooth
