  • Dayton Audio DS115-8 4" Designer Series Woofer Speaker
Dayton Audio
Part #295-424
Dayton Audio
Part #295-424
Model: DS115-8
More than just a pretty speaker, the Dayton Audio Designer Series DS115-8 4" woofer features an extremely neutral response and high Xmax capability.
  • Coated paper cone, half roll rubber surround for durability and accurate reproduction
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Optimized to yield a low 3 dB down point and high potential output in a reasonably sized cabinet
  • Vented pole piece for minimized power compression and maximized reliability
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
  • Smooth frequency response and linear roll-off simplify filter design, assuring good results with off-the-shelf crossovers
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
Your Price: $19.99
MSRP: $31.99
Save $12.00 (38%)
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
• Suggested enclosures:
Sealed cabinet:Type: Closed (alpha 1.9), Qtc 0.55; Size (internal) including volume displaced by driver: 0.1 ft³; Internal cabinet dimensions (golden ratio): 9"H x 5-1/2"W x 3-1/2"DTypical results:3 dB down-point (f3): 135 Hz; Low frequency limit at rated power without exceeding conventional Xmax (i.e. (voice coil length – gap height) / 2)): 70 Hz.
Vented cabinet:Type: Bass reflex; Size (internal) including volume displaced by driver and port: 0.12 ft³; Internal cabinet dimensions (golden ratio): 9-1/2"H x 5-7/8"W x 3-5/8"D; Port dimensions (with flared exit): 1" dia. x 6"L. Typical results:3 dB down-point (f3): 73 Hz; Tuning frequency (fb): 69 Hz; Low frequency limit at rated power without exceeding conventional Xmax (i.e. (voice coil length – gap height) / 2)): 55 Hz.
Frequency response (FRD) and Impedance (ZMA) data files available to assist in crossover and enclosure modeling.
ModelDS115-8
Part Number295-424
UPC844632095382
Weight1.85
Nominal Diameter4"
Bolt Circle Diameter4.21
Power Handling (RMS)35 Watts
Power Handling (MAX)70 Watts
Frequency Response60 to 8,000Hz
Sensitivity85.3dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)55.2Hz
DC Resistance (Re)5.8Ω
Voice Coil Inductance (Le)0.8mH
Mechanical Q (Qms)2.1
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)0.15ft³
Mechanical Compliance of Suspension (Cms)1.05mm/N
BL Product (BL)5.88T·m
Diaphragm Mass Inc. Airload (Mms)7.9g
Maximum Linear Excursion (Xmax)4.1mm
Surface Area of Cone (Sd)54.1cm²
Cone MaterialCoated Paper
Voice Coil FormerAluminum
Overall Outside Diameter4.55"
Baffle Cutout Diameter3.69"
Depth2.15"
Sealed Volume0.07ft³
Sealed F3135Hz
Vented Volume0.12ft³
Vented F365Hz
